'87 clutch master cylinder reinforcment plate
Old Apr 20, 2006 | 03:09 PM
blindlightguy's Avatar
blindlightguy
So on the advice of others on this forum I bought a reinforcment bracket for my clutch master cylinder as there is a lot of deflection in the fire wall when I step on the clutch.
It was suggested that it was 5 dollar part and that it would be easy to install.
Well the 5 dollar part is for 88 and newer. The 87 version was 16 dollars. Well I bought it and just got it in today. The instructions are very confusing and dautning.
I am wondering if any one else out there has installed this part.
Any advice would be great.
Blindlightguy
Old Apr 20, 2006 | 07:25 PM
frederic's Avatar
frederic
This should be a squarish plate with several holes in it - one big one in the center for the rod from the brake pedal (or clutch pedal) to go through, and mounting bolts that line up with the master cylinder (brake or clutch, depening) on the other side. It's a matter of removing the bolts, disconnecting the linkage, and slipping the plate between the "stuff" on the inside, and the firewall, then bolting through it all with the existing bolts.
Old Apr 20, 2006 | 11:00 PM
EPNCSU2006's Avatar
EPNCSU2006
Can you take a picture of the bracket before you install it?
Old Apr 20, 2006 | 11:30 PM
blindlightguy
Yeah,
It's nothing too complex. One could certainly make one if thats what your interested in.
Blindlightguy
Old Apr 20, 2006 | 11:35 PM
EPNCSU2006's Avatar
EPNCSU2006
That's something I've thought about doing
blindlightguy
Jul 29, 2006 08:27 AM
blindlightguy
Jul 5, 2006 04:29 PM
blindlightguy
Dec 6, 2005 11:36 AM
blindlightguy
Sep 18, 2005 10:51 PM
