'87 Tranny
Old Jul 28, 2006 | 11:00 AM
blindlightguy's Avatar
blindlightguy
'87 Tranny
I am finishing up a clutch replacment on my '87 f150 and I have ran into a few problems.
The first is that the upper passanger side bolt to the bell housing from the tranny has some sort of problem with the threads. It will thread in but it wont snug down, it just keeps turning. I am trying to decide if Hellicoil or a tap and a bigger bolt is the solution.
The other problem is that I am having is that I can not get my stick back in the tranny. It is a three speed w/ overdrive.
There must be a trick, to it and I haven't figured it out yet.
Any help would be great.
Blindlightguy
Old Jul 28, 2006 | 06:40 PM
blindlightguy
No one has any experince w/ this?
Blindlightguy
Old Jul 28, 2006 | 10:25 PM
blindlightguy
So I think I have determined that I have a TOD transmission if that helps any one.
The shop manual seems to make it very easy, but when I installed it the way it seemed to want to go in, it wouldn't shift, or didn't feel like it was shifting like it once did.
Is there a chance something fell out or loose, in it's moving around?
Thanks,
Blindlightguy
Old Jul 29, 2006 | 08:27 AM
stuart1's Avatar
stuart1
Stick a small screw driver in the stripped hole and check for depth.
Compare the depth to the bolts you now have.
You may be able to put a longer one in.
Look into the transmission.
There is what is referred to as gates.
There should be either a square or circular hole.
It is necessary the square or circle be aligned. That means it is in neutral.
blindlightguy
Feb 21, 2018 12:27 AM
blindlightguy
Jul 5, 2006 04:29 PM
blindlightguy
Dec 6, 2005 11:36 AM
blindlightguy
Sep 18, 2005 10:51 PM
