Sponsored by: Innova
Need Help with Code Alarm CA670 Install
Old Apr 20, 2006 | 10:33 AM
trublu gen2's Avatar
trublu gen2
Hi Everyone,
I'm new to this forum and have a few questions about the Code Alarm I'm installing in my 02 Lightning. I'm using the install manual that came with the alarm and the reference manuals at gemsen. I'm still in the planning phase. I want to make sure I know exactly which wires to splice into.
1) Does the negative unlock/positive lock(blue) wire on the alarm connect to the door lock(pink/yellow) wire on the truck?
2) The answer to the last question should answer this one...Does the negative lock/positive unlock(green) wire on the alarm connect to the door unlock(pink/green) wire on the truck?
3) Does the Unlock switch sense input(lt blue/green) wire on the alarm connect to the Passenger door unlock(pink/orange) wire on the truck? The code alarm manual says only make this connection if you are using the factory transmitter to arm/diasarm, I'm not. It does seem like the 2nd stage unlock(blue/green) wire on the alarm would need to be connected to the Passenger door unlock for the priority drivers door unlock to function correctly. Is that correct?
4) Do the positive and negative door trigger wires on the alarm both get connected to the dome light on the truck? Does this connection affect the priority drivers door unlock feature and the usage of the keypad?
Thanks for any and all input.
Old Apr 20, 2006 | 11:10 AM
fordboy_52's Avatar
fordboy_52
Welcome trublu gen2 to FTE! Please take a moment to read the forum rules and policies and if you have and questions please feel free to private message me! Now sit tight and someone will help you with your questions shortly. thanks agian!
Matt
Lee Lichterman
Electrical Systems/Wiring
Sep 13, 2022 04:41 AM
xmontex4
Mar 25, 2018 03:08 PM
Nobody-special
May 10, 2017 08:14 AM
7622RM
1983 - 2012 Ranger & B-Series
Oct 23, 2013 08:33 PM
Ponch85RS
Jan 22, 2009 08:06 PM
