Remote Start Nightmare
Old Jan 21, 2009 | 03:41 PM
Ponch85RS's Avatar
Ponch85RS
4wd High
well is I'm ever going to solve this problem, this is the right place. I'm currently in the middle of installing my Ford remote Start. And things are looking pretty grim. 1. My truck is a 99, and this is the new style remote start. So far I've got all the wires connected, except the LT. Green (unlock switch input), White/Blue (Arm input), Brown (disarm input) and the blue/green (Driver door unlock input) Now according to this, I'm guessing my unlock/lock should not work, but it does...very strange. My tach lead is connected to the coil of the #1 cylinder, but I guess its not receiving signal, because the truck will crank, but wont turn over in remote start mode. of all the wires I have not connected yet, I cannot find where to connect them too! I swear this truck doesn't even have a pink/orange wire, or a red/and orange wire... Is there some different wiring diagram I would be using because my truck is older? I'm follow the directions for an 02, who I thought would be the same thing. And if it wasn't for this site, i would have been screwed my girl bought me this system for Christmas, and Ive been outting it in for almost a week now.... hahahahah
Old Jan 21, 2009 | 07:31 PM
ReAX's Avatar
ReAX
One problem at a time. I take it this is the newer Code Alarm unit than the old silver/gold/bronze ones. And that you have a tech sheet like this.
Constant 12V+ Green/Purple or Yellow Ignition Switch Harness
Starter Red/Light Blue Ignition Switch Harness
Ignition Red/Black or Blue/Green Ignition Switch Harness
Ignition 2 Gray/Yellow Ignition Switch Harness
Ignition 3 Dark Red/Black Ignition Switch Harness
Accessory Gray/Yellow or Blue/White Ignition Switch Harness
Tach White/Pink BCM, Pin 48 of 104 Pin Connector or Pin19 if Diesel
Neutral Safety Wire Red/Light Blue Ignition Switch
Brake Switch Red Brake Switch
Trunk Pin n/a
Parking Lights Brown (+) Driver's Kick Panel or Light Switch
Head Lamp Red/Yellow (+) Light Switch
Factory Disarm Dark Green/Purple(-) Driver's Kick Panel
Door Trigger Black/Blue (+) 40 Pin Connector Firewall behind Driver's Dash
Door Lock Pink/Yellow High Driver's Dash Negative Trigger w/Keyless Entry
Door Unlock Pink/Light Green Reverse Polarity w/o Keyless Entry
Driver's Lock Pink/Black Driver's Door Boot
Driver's Unlock Red/Orange Driver's Door Boot
Passenger Unlock Pink/Orange Keyless Module
Horn Wire Dark Blue (-) Brown 6 Pin Connector behind Driver's Dash
Windows Up LF=White/Black, RF=White/Yellow, LR=Gray/Orange, RR=Yellow/Black
Windows Down LF=Orange/White, RF=Tan/Light Blue, LR=Yellow/Light Blue, RR=Red/Blue
Old Jan 21, 2009 | 07:39 PM
ReAX's Avatar
ReAX
The 02 had a VSM which it appears the 99 does not. Input=Intrusion and is a sensing wire, not an activating wire. So please double check the wording on the wires.
There are two wires on the coil, one has a constant state and the other changes. You can test for the right one using a DMM set on the VAC (volts AC). The right wire will show increasing VAC as the motor revs. This wire probably doesn't have to be connected for the RS to start (turn the engine over), just to stop the starter from turning once it's running and prevent trying again every few seconds.
There are a couple of wires you want to find in the column for the RS. Starter and IGN are the two most necessary. If the kit has an external relay for the start kill/anti-grind, you need to pay attention to which side goes to the column half of the wire and which to the vehicle half of the wire (this wire should be cut for the kill to work.) With the starter and ign wires energized the vehicle will start.
I picked out the tech sheet for a F-series, ranger or excursion or anything else may be different. And anything other than a superduty has a high probability of needing a PATS bypass.
Old Jan 22, 2009 | 08:06 PM
Ponch85RS's Avatar
Ponch85RS
4wd High
http://www.clubfte.com/users/hawkins/manuals.htm
Yes, it is a newer code RS.
Im using the wiring diagram for the '02/'03 Expedition/Navigator from this link. (one of the Ford techs on here hooked it up with the Ford instillation instructions) and I've got almost eveything connected except A-12, A-11, A-9, and A-24 of the Driver's side kick panel harness.
This thing has really got me thinking... thanks for the assistance brothers...
