I Need More Power!!!
Old Apr 19, 2006 | 03:27 PM
1972 project's Avatar
1972 project
Smile I Need More Power!!!
Ok.. my 1972 F250 has a 360, I know just enough to change the oil and spark plugs, what can I do to increase the horse power? Anyone done this before?
Thanks,
Peter
Old Apr 19, 2006 | 04:23 PM
bertha66's Avatar
bertha66
Well Peter, welcome to the site, how much power are you looking for? If you are not out to do a rebuild you may want to start with a new 4v carb and manifold and a set of headers with duel pipes. Just a place to start IMHO. Allen
Old Apr 19, 2006 | 04:48 PM
sandhillmike's Avatar
sandhillmike
OK, this will be no help, but there is an old saying: "speed costs money, how fast do you want to go." But be more specific, do you want more top end speed, more low end grunt for towing or hauling, or what?
Old Apr 19, 2006 | 06:30 PM
1972 project
I just want to smoke the tires ! I really don't take it on the freeway, I just go back and forth from Home Depot.
Old Apr 19, 2006 | 06:45 PM
1972 project
I Need More Power
My truck has headers on it and I replaced all of the hoses. Should I replace the core, inake manifold and carb. or drop in a good 390? I dont want to spend more than $3, 000.
Old Apr 19, 2006 | 07:40 PM
charles jones's Avatar
charles jones
How many miles are on this engine?
Is it all stock inside the engine?
What transmission?
For $3000.00 you can have a cam, 4 barrel carb. and 4 barrel intake installed for you.
The built 390 is going to exceed your budget if you have it done.
Just the carb and intake with your headers will wake that 360 up enough to smoke a lot of tires. JMO Charles
Old Apr 19, 2006 | 07:41 PM
Fomoko1's Avatar
Fomoko1
390 would a quick simple drop in but a 460 would get you more power and alot more performance parts available for even more upgrades later.
Old Apr 20, 2006 | 07:57 AM
jowilker's Avatar
jowilker
A good tune up, and an upgrade to electronic ign. might give you the most bang for the buck. A Petronix will cost about a hundred bucks, not sure about a durispark.
Any ol 360 worth it salt should roll the tire. You may have to hold the brake and keep mashing the gas until it happens. That aint nearly as important to me as getting good mpgs so I don't worry about it.
John
Old Apr 20, 2006 | 01:30 PM
Fomoko1's Avatar
Fomoko1
Good point on the tuneup, more power plus it will save on fuel. All of mine vehicles are stock except for the 67 Mustang.
Old Apr 20, 2006 | 01:32 PM
1972 project
Question
Ok so if I go the route of having the 4 barrel carb. and 4 barrel intake installed, are there any brand recomendations? Holley, Edelbrock?
Could I hold off on the cam and do it later if I still wasn't satisfied?
Please explain why an electronic ignition would have a noticable effect on performance.
Peter
WA
Old Apr 20, 2006 | 01:35 PM
1972 project
I did the tune-up changed the plugs and all the hoses. I am thinking about removing the factory A/C unit, dont know fi I should toss it or sell it.
Peter
WA
Old Apr 20, 2006 | 02:36 PM
70blue's Avatar
70blue
I gather from this you are concerned about takeoff power. I also gather topend is probably not much of a concern. You could go with a lower rearend gear to get more takeoff with the power you have. Ofcourse that would take some from your topend. With the lower gear it will pull better too.
Old Apr 20, 2006 | 03:07 PM
1972 project
Any recomendations for new/used 1972 ford parts online? (4 barrel carb. and 4 barrel intake )
Old Apr 21, 2006 | 06:43 AM
jowilker's Avatar
jowilker
I put a 4 barrel on my truck and didn't notice any change. Rebuild the engine to run a 4 barrel and you may have a different deal.
John
Old Apr 21, 2006 | 10:51 AM
1972 project
Question
how invoved ($$$?) is it to rebuild/modify the 360 2 barrel into a 4 barrel?
