Silly quations....
Old Dec 27, 2006 | 05:39 AM
Pablo-UA's Avatar
Pablo-UA
Silly quations....
I'm a new Ranger driver, so I have many stuped quations. Well, the first is, what spark plugs to use, what is the plug wrench size? Where is the OBD-2 connector?
I have 4.0. How many camshafts there? one ore 2 in heads. How many valves there? 24 ore 12? What is the tranny there? I know, that I have auto only.
___________
Ranger XLT '01/ 4.0 Auto
Aero XL '89 3.0 5st tranny
Old Dec 27, 2006 | 01:03 PM
Alan D.'s Avatar
Alan D.
Whoa. Ok your running a 4.0L SOCH (Single OverHead Cam). Use the sparkplugs recomended by your owners maunual. The motorcrafts are the only ones that get good gas mileage and good plug life. I'm running the older OHV, so they might have changed the plugs since then. I though i heard something about the soch's having 18, but that doesn't make much sence, so i'ld say it's 12 or 18.
Old Dec 27, 2006 | 01:26 PM
wendell borror's Avatar
wendell borror
Glad to hear that you got you a ranger, also glad you got the 4.0, it's a single over head cam design, 1 cam per head, for a total of 2. 207 american horse power and 238 american foot pounds of torque, don't know what that is in metric.. I'm not sure about the plugs, cause I haven't had to change mine yet. Like Alan said, use motorcraft if you can get them, they work really well in the 4.0. I can't tell you about your auto tranny, as I'm a manual tranny guy, but there will be others a long to help you there. Good luck with your new to you, ranger, I know you've been wanting one from our past discussions.
Old Dec 27, 2006 | 01:43 PM
FXFrank's Avatar
FXFrank
plug number should be AGSF-34-FP or SP 440
Old Dec 27, 2006 | 03:27 PM
wes555's Avatar
wes555
The spark plug socket size is 5/8; make sure you have one with the rubber thingy inside so you don’t crack the insulator. You also want to have a good selection of extensions and universals to make removal /instillation easier. Also a short piece of rubber hose will make starting the plugs easier.
I have a ’99 Ranger, the OBD-II connector in under a plastic cover below the steering column, between the parking brake release and the hood release.
Old Dec 27, 2006 | 04:58 PM
RangerPilot's Avatar
RangerPilot
Tranny's a 5R55E. 5 speed automatic.
Use Motorcraft or Autolite plugs. As wes555 said, it's a 5/8" socket size.
12 valves, 2 per cylinder.
Old Dec 28, 2006 | 01:02 AM
Pablo-UA's Avatar
Pablo-UA
Thanks! But where is the OBD -II connector?
Old Dec 28, 2006 | 02:30 AM
PW01's Avatar
PW01
Next to the hood release lever.
Old Dec 28, 2006 | 03:28 AM
Pablo-UA's Avatar
Pablo-UA
I have OBD-II scan program for lap top, and I can read codes, but who ever sow a program for ECU parametrisation for Ford, like VW VAG Tool ore Mercedes DAS, that work thrue k-l line adapter?
Old Dec 28, 2006 | 03:48 AM
Pablo-UA's Avatar
Pablo-UA
And the other quation! What is used for timing? Belt ore CHain?
Old Dec 28, 2006 | 05:15 AM
Pablo-UA's Avatar
Pablo-UA
Thank you for your replys! Happy new year!!!!
Old Dec 28, 2006 | 04:56 PM
RangerPilot
lol.
It's a timing chain, no maintenance required unless you have the engine out you might as well replace it.
Are you looking for a programmer for it?
Old Dec 28, 2006 | 07:08 PM
bcjim's Avatar
bcjim
Are there Ford dealers in the Ukraine? Or is it just Ukraine, people always seem to say "The Ukraine", not sure which is right. Are dealers there bloodsuckers too?
Old Dec 29, 2006 | 12:11 AM
Pablo-UA's Avatar
Pablo-UA
Dealers are bloodsuckers everywere!
And I have to be hornest.... I work for Mercedes Truck dealer.... So I have can-scanners, O-scopes and other modern toys, but with Ranger I can reed codes only.
What is the programmer kit for Ranger.... Just a Computer program for K-L line adaptor?
Old Dec 29, 2006 | 01:47 AM
RangerPilot
What is a K-L line adaptor? I have no idea what you're talking about...haven't heard that one.
