Hot wire
Old Apr 17, 2006 | 06:40 PM
maples01's Avatar
maples01
Hot wire
I have a wire on the ignition switch of my 78 that is hot to the touch when the key is on, I'm trying to figure out where it goes, looks a light red or orange, with a tiny blue stripe or two. I know this is an indication of a short, needs solved before it burns up, I want to know where it goes. Everything works great, like it should, other than a dask light is out, but that's a blown bulb, I'll get to it later.
I have added a MSD Blaster 2 coil to the duraspark ignition system, I was beginning to wonder if it requires the resistor, but surely not on an elect ignition. Before I go tchanging everything, I'd like to know what the wire goes to, to chase it and solve it that way, instead of replacing everything hoping to eventually get it.
Old Apr 17, 2006 | 06:48 PM
76 F-150 390FE's Avatar
76 F-150 390FE
its a red and blue wire and it goes to the neutral saftey switch.
Old Apr 17, 2006 | 09:25 PM
Mil1ion's Avatar
Mil1ion
This should help.
http://www.clubfte.com/users/mil1ion...nFaulttest.JPG
The Ignition resistance wire on the switch is PINK.
Old Apr 17, 2006 | 10:20 PM
maples01's Avatar
maples01
OK, according to the switch diagram given, it's ign 1, it's the far side, at the ashtray. So I need to check the coil, to see that it's wired correctly, and not backward, then the disconnect on the firewall will require cleaning again. Coil is pretty old, but only way I'll replace it, is if bad, or upgrade to HEI. I couldn't be sure of it's color, just location.
Old Apr 17, 2006 | 10:23 PM
Mil1ion's Avatar
Mil1ion
Ford ignition is powered with 8 volts.
Most aftermarket ignitions require 12 volts.
DKluke
Oct 25, 2013 11:18 PM
The Fool On Th Hill
Apr 11, 2012 12:47 PM
Alan L.
Oct 31, 2009 04:55 PM
Ztitan
May 20, 2008 11:53 PM
kenshi
May 9, 2007 04:57 PM
