351 not running right
Old Apr 24, 2006 | 09:50 PM
Bdox's Avatar
Bdox
Richening is basically rejetting the carb.
But you really need to insure that both cam and ignition timing is correct. It sounds like the chain is stretched or jumped a tooth. Do you know how to test for this?
Also, if it is lean, and it may not be, first make sure that the float level is correct before you start changing jets. Also be certain that there are no vacuum leaks too.
Old Apr 25, 2006 | 10:03 PM
hatcatz's Avatar
hatcatz
well i thank u for your help bdox but unfortunatly i dont have the old carb shes got the fuelinjection
Old Apr 25, 2006 | 10:08 PM
Bdox's Avatar
Bdox
Sorry about that. I should have paid closer attention to your first post.
So, if it's lean, first check your fuel pressure.
Old Apr 26, 2006 | 08:47 PM
hatcatz's Avatar
hatcatz
it ok bdox ill check and thanks
Old Apr 27, 2006 | 02:41 PM
MrG4x4's Avatar
MrG4x4
Timing is your best bet for the problem. If and when it's correct, and you still have the same problem then probably a lean condition is occuring as suggested. Fuel pressure definately would be a good candidate for that, at idle probably should be around 32 psi and 40 as you get closer to wide open throttle. Your stock fuel pressure regulator should have a vacuum line on it. Dirty fuel filter could be a cause for poor fuel pressure, but not likely at idle. You also might try pulling the codes of the computer, they may help verify the lean condition problem.
USCG_PA
Jun 11, 2014 02:26 AM
bruno2
219
Apr 12, 2013 09:43 PM
Ted Bell
Oct 6, 2011 01:25 PM
GI8U2racing
Apr 29, 2010 03:12 PM
biederboat
1978 - 1996 Big Bronco
15
Nov 28, 2005 01:49 PM
