351 not running right
Old Apr 16, 2006 | 02:31 PM
hatcatz's Avatar
hatcatz
well heres the story took the 89 f250 apart for a intake leak then figured im this far might as well do head gaskets too so i take the heads off get brand new oem ones from michigan motor exchange and put em on tourque evrything down good and right order. get her all back together start sounds good at idle minus the exhaust leak..... looking at it realize my manifolds are glowing bright red in the bright sunlight obvious problem... drive it in to muffler man to get exhaust no get up or nething.... pedal to the floor tops out at 25mph in 10 mins... muffler man says that ive either got a cracked block or cracked head but they wont tear down to figure it out.... so if u guys could help me any it would b nice. so my question is what do u guys think it could be if nessacary ask me some questions and ill answer them the best to help me figure this out..... thank you bryan
Old Apr 16, 2006 | 03:40 PM
Kemicalburns's Avatar
Kemicalburns
why did you replace the head gaskets to begin with?
Old Apr 16, 2006 | 04:00 PM
hatcatz's Avatar
hatcatz
i replaced them because i was told that the motor was rebuilt but didnt trust it as i already needed intake gaskets not 3 mths after a rebuild and upon removeal i found my head was cracked so just preventitive maintence...
Old Apr 16, 2006 | 04:43 PM
Bdox's Avatar
Bdox
Any chance that something got down into the exhaust and caused the cat to plug up?
Old Apr 16, 2006 | 06:56 PM
Kemicalburns
so you replaced the heads on both sides or just the one? what head are you running now? new or yard heads?
Old Apr 16, 2006 | 07:19 PM
j&bsuv's Avatar
j&bsuv
when its running is the exaust flow normal ? I had a cat clog on an old pontiac it didnt run for **** until I cut the cat opened I drilled a hole in it and took all the little beads out of it then welded it back shut never a prob after that .
Old Apr 16, 2006 | 09:19 PM
hatcatz's Avatar
hatcatz
well i replaced both heads with brand new remanufactured stock heads... and now that u guys mention it the flow out the tail wasnt really all that good.... i mean i plan on going catless when i do the exhaust but that wont be till after shes running so ill cut her out.....
Old Apr 16, 2006 | 09:26 PM
j&bsuv's Avatar
j&bsuv
sounds like a plan to me !! good luck keep us posted on how it goes!
Jeff
Old Apr 18, 2006 | 09:25 PM
hatcatz's Avatar
hatcatz
well i pulled the cat tonight ... looked thro it can seee fer miles literal nothing in it at alll ... cant strt her tonight but will in the morning and illl let u guys no if it helped any
Old Apr 18, 2006 | 09:41 PM
pfogle's Avatar
pfogle
Glowing exhaust indicates either a lean condition, or improper timing. The no power also tells me the timing is way off. Cylinders are numbered starting at the front on the passenger side 1 2 3 4, and 5 6 7 8 on the drivers side. Make sute you're got your distributor in right. I think in '89 it's EFI, so you might try changing the fuel filter.
Old Apr 18, 2006 | 10:06 PM
Blurry94's Avatar
Blurry94
I agree!!!
Old Apr 23, 2006 | 02:45 PM
hatcatz's Avatar
hatcatz
welll cut the cat off only to find someone already had her gutted so i got nothiong out of the night she stll wont top oyut at more then 25 so idk now besides timing....being offf..... now i was told im runniong really lean how do i fix that
Old Apr 23, 2006 | 11:01 PM
Blurry94's Avatar
Blurry94
It's possible that the motor is running lean, but the only way to know for sure is to monitor your A/F ratios with a wideband.
Old Apr 23, 2006 | 11:27 PM
Bdox's Avatar
Bdox
Sounds like time to recheck the cam timing and ignition timing.
Old Apr 24, 2006 | 09:28 PM
hatcatz's Avatar
hatcatz
yea i cant thank you guys enuff i no im not very outhere with helping others but with ypur guyses help ill be sure to help the next time i think i have an idea.. but how would i make the truck run a bit richer
bryan
