Installing Drip Rail Chrome...
Old Sep 3, 2002 | 08:48 AM
GolferSA's Avatar
GolferSA
[updated:LAST EDITED ON 03-Sep-02 AT 10:26 AM (EST)]I just acquired the drip rail chrome, in excellent condition... did not take it off, so I'm kinda clueless how to re-install it. Anyone done this before? Looks like you snap it on and then pinch it down... somehow. Open to suggestions, thanks!
GolferSA
67 Ford F100 Custom Cab
352V8 C6 Auto Factory Air
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5688&.jpg
Check out my gallery!
Old Sep 3, 2002 | 10:03 AM
oleblue70's Avatar
oleblue70
You are bringing back bad memories!
The rule of thumb is if you build a truck that has it on,leave it and mask it off,I dont care how good of a resto it is.
Now for a re-install.If the two peices the connect over the windshield appear to be twisted in any way,forget it.They took them off with to much space between "prys".Most people use a bottle opener.Works good.
The side peices are always good to go but the top is a drag.This job ranks right up there with the chrome winshield trim install.
Sorry for no good vibes.
Old Sep 3, 2002 | 12:34 PM
Mil1ion's Avatar
Mil1ion
This install allows you to see how well you have finger thumb co-ordination.
It sounds like you pegged it.
The main concern above the door is getting the curve at the right place.
I suggest a *holding the piece while you install* partner.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Sep 3, 2002 | 02:36 PM
oleblue70's Avatar
oleblue70
Definetly!
Also make sure you sand any thick paint off and clean the actual drip rail.They are tight and that means forcing it and also possible dents in it as you snap it over.
This is not a impossible job.I hate to sound so negitive.
bottom line:
Lay your two upper peices on a flat table and slide them together.If they sit nice go for it,if they appear to be slightly tweaked,save your energy for somethinh else.
Take care.
Old Sep 3, 2002 | 09:13 PM
Mike W's Avatar
Mike W
I wonder if the chrome or stainless promotes rust on the steel drip rail over time. Anyone seen this?
Old Sep 3, 2002 | 10:38 PM
oleblue70's Avatar
oleblue70
Mike,
I dont think so.The moulding is a super tight fit to the rails.And the factory seam sealer area is still exposed.The last truck i pulled it off of was a '72 that was a total rot out.The roof was the only good thing on the truck!It was perfect green paint under the drip rail trim.
Old Sep 3, 2002 | 10:42 PM
GolferSA's Avatar
GolferSA
[updated:LAST EDITED ON 03-Sep-02 AT 11:43 PM (EST)]The trim is in excellent condition, taken off nicely with no dings or bends, straight and not twisted. I'm thinking a little silicon sealer as a lube, plus will dry and help hold and seal... thoughts?
It's not at the top of my "to do" list, but I'll keep y'all posted on how it goes... when, if, whatever.
GolferSA
golfersa@netscape.net
Old Sep 4, 2002 | 08:17 AM
oleblue70's Avatar
oleblue70
If thats the case then it will go on.Your truck would look good with it.I like the color combo.
Have a helper and a clear idea of how you are going to go about it.
Old Sep 5, 2002 | 10:44 PM
GolferSA's Avatar
GolferSA
OleBlue...
Thanks... how many 6 packs to install this?
GolferSA
Old Sep 6, 2002 | 08:09 AM
oleblue70's Avatar
oleblue70
True.I dont know,I was nervous enough the first time i installed it.
One of the best tools in this job is the meaty part of your hand to bump it on.It does snap into place.Another good tool i found was those big plastic 3lb hammers with the rubber face.Just never hit the trim in the center of it,it will show,get the bottom started and bump the top edges with the hammer.
Old Sep 11, 2002 | 12:19 PM
Art's Avatar
Art
Good tip about the big soft hammer oleblue...
The other trick I know of is to "roll" or "twist" the trim onto the drip rail - first hook the sharp side and then "snap" the side with the wider flange (closest to the door if my memory is correct) over the drip rail. The side with the wider flange will act as a ramp. You should hear the trim "snap" in place. Don't try to snap both sides on at the same time.
I have sucessfully swapped that chrome on trucks without damaging it - just move along slowly in small, even increments to avoid bending/twisting the trim.
Art
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=3467&.jpg
Old Sep 14, 2002 | 02:26 PM
oleblue70's Avatar
oleblue70
Hey it's Art!
Havn't seen you around.Good to see your still around.
Truck looks good.Still runnin the big wedge in there?
Gotta love them 440's.I have one but it's froze solid
Old Sep 14, 2002 | 05:59 PM
jor's Avatar
jor
Rabbit72
Aug 6, 2015 01:00 PM
GolferSA
Sep 26, 2004 05:44 PM
GolferSA
Texas Chapter
Nov 18, 2002 10:40 PM
GolferSA
Texas Chapter
Sep 23, 2002 11:40 PM
GolferSA
Texas Chapter
Jun 18, 2002 10:51 AM
