Diesel/V10
I am considering two trucks, roughly same price, will put 3000lb (loaded) camper and pull 5000lb boat. f-250 has camper pkg, f-350 does not.
Grodyman
Now my 04' was 8' bed that gets you a 38 gallon tank, around here I was down to 1/4 tank by 300 miles or less,,,, now my 06' PSD is the short bed (6.3/4'), that nets you 29 gallon tank, 300 miles or so,,at 1/4 tank again,,I did get 405 miles, best tank so far, with going on 5 k miles on it already, picked 06' up on 1/6/06.
With my experience I think your location, makes a difference, with what mpg you get,,,rather flat land area,,better mpg's,,,hills in your area,,,a little less mpg,,,,so whats your driving area like ?????
V-10 hands down. Just think of all the gas you can buy for the $5000 diesel option and $1400 tranny upgrade. Not to mention the quietness, smoothness, clean smelling, and instant response to the go peddle the V-10 delivers.
Grodyman
Easy choice. Diesel
Grodyman said in the original post that both truck were roughly the same price.
Grodyman
With the later V10s (2001 and up) you can sleep at night soundly knowing your engine isn't going to puke out when you need it most.
Plus I'd never own a 2wd pickup. I use the 4wd too much in the winter and for working offroad on my land and on hunting trips. A 2wd would be useless for my needs. Plus a 4wd sits alot higher off the ground and just looks better in my opinion!
Also the V10 is a 350, right? So you're going to gain a little bit or weight capacity on the GVWR over the 250 which is a nice factor as well.
