1978 - 1996 Big Bronco
front hub/rotor question????????
Old Apr 15, 2006 | 11:12 PM
JetBlackBronco's Avatar
JetBlackBronco
Question front hub/rotor question????????
ok so a situation came up, that i really need/want to replace my front rotors/hub/bearings/lug studs.....
long story short...wheel locks....broke the key...cut off studs...only have 4 lugs on 3 wheels
so the front hub/rotors, the old ones, are very rusty and worn. so i want to replace them, i saw the ones on broncograveyard.com, and found others on RockAuto.com. now i know these are the right parts, the hub rotor assmebly.
now NPD has listed under "Rotor" the part, for only $39...
could that only be the rotor? or is it all one peice with the hub? i havnt had a chance to take it apart and look, but are the hubs on my '91 one peice?
Old Apr 15, 2006 | 11:51 PM
nv_brewer's Avatar
nv_brewer
The hubs and rotors on a 91 are two pieces. The rotor is held onto the hub by the lug bolts.
Old Apr 15, 2006 | 11:52 PM
Streetgang's Avatar
Streetgang
No they are two pieces. The price you found for $39 sounds like its just for the rotor.
When I did mine I got the rotor hub assemblies from Rock auto. They are Raybestos PG Plus, and they came with the bearing races, and lugs installed. That makes the job very easy.....I also recommend replacing the seals, and using Timkin brand wheel bearings.
You may want to also replace the spindle bearing while your in there.....I did not, but next time I replace the rotors I will be also replacing them.
Old Apr 16, 2006 | 01:23 PM
greystreak92's Avatar
greystreak92
Yeah, the fun part about replacing just the rotors is driving out ten (five per) wheel studs to free the rotors from the hubs.
Old Apr 17, 2006 | 01:42 PM
andym's Avatar
andym
Buying the pre-assembled rotors is the only way to go. You'll warp the rotors installing the wheel studs and then you'll need to get them turned once they're together. Unless you work in a brake shop and have a lathe right there, it's just too much hassle.
Old Apr 17, 2006 | 05:32 PM
BroncoRoadKill's Avatar
BroncoRoadKill
I have always changed the rotors and put the hubs on the new rotors, have never had a problem and my 82 has the same hubs since I bought the truck.
Old Apr 18, 2006 | 02:53 PM
greystreak92
I'll second BRK's idea. I've never had a problem replacing rotors by driving out the studs and replacing them. You do need to support your work so that you don't damage the components. I've successfully done the swap two or three times on different trucks.
Old Apr 18, 2006 | 03:38 PM
johnarahill's Avatar
johnarahill
Even more fun is trying to drive all the lugs back through the new rotor without tearing anything up, if you haven't had too many beers it should go smoothly.. .
Old Apr 18, 2006 | 09:05 PM
fatboyf150's Avatar
fatboyf150
Smile
iwork in a tire and brake shop and its no problem changing the rotor on the hub. lay the rotor on a table, take big hammer and smash out the lug bolts, comes right apart, we always replace the lugs when we replace the rotor. place the rotor in a vice face down where the lugs will come through, use a long punch, we use a broke 3/4 drive extension, drive the lugs right in. no problem and you wonr warp the rotor kenny
Old Apr 18, 2006 | 09:32 PM
Grogtronics's Avatar
Grogtronics
when I swapped out my rotors I started my studs with a brass punch and then I pulled the studs the rest of the way in with the lug nuts it worked pretty easy and very little effort. ( use plenty of anti sieze on the threads)
Old Apr 19, 2006 | 05:48 AM
muckypaws's Avatar
muckypaws
I changed my rotors at the weekend and with a 3 ton fly press the studs came out with little effort. That was the easy part....
The harder part is retracting the caliper piston enough to let the caliper fit with the extra thick rotors and new pads.
Once its all reassembled check the lug nuts after a 100miles or so as the studs might not have fully bottomed out when you first tightened them and you'll find you now have loose lug nuts from the studs moving with wheel vibration.
Jlongwell1
Oct 18, 2015 06:24 AM
willydad
Oct 7, 2014 08:18 PM
BBF Dude
37
Jul 10, 2012 08:48 PM
Hayne
16
Nov 15, 2010 01:45 AM
w1!dbill
Jan 20, 2006 08:41 PM
