Trailer bearing adjustment?
Old Apr 15, 2006 | 05:41 AM
sportscar's Avatar
sportscar
I recently repacked the bearings on my open car hauler. After approximately 350 miles the wheels have some play/end shake. Just enough to feel, maybe a 0.010 inch or so. Is this good or should there be no perceivable play?
Old Apr 15, 2006 | 06:29 AM
JOE-M's Avatar
JOE-M
There will be a little play when you shake the wheel. If you tighten them to the point of zero movement the bearings will burn out from overheating. Sounds like they are O.K. to me. Check them in a few more hundred miles and re-tighten them if they get looser.
Joe
Old Apr 15, 2006 | 06:58 AM
001-F DORF's Avatar
001-F DORF
That's correct, they should have a little play.
Dorf
Old Apr 16, 2006 | 07:52 AM
rebocardo's Avatar
rebocardo
What I do is put them on where the wheel spins just barely, back them off a 1/2 a turn or so, now it has "some" resistance left. Put everything back together and take a short ride. Then jack the trailer up, if the wheel does not spin freely and make many revolutions, then the bearing is too tight.
During my first haul, I pull over and feel each hub/wheel after 10 miles or so to make sure it is not hot. Then I check them whenever I stop.
To add to what everyone else has said, the other thing about overtightening is depending on design, even if you back off, you can destroy the grease seal too
tshrager
17
Feb 26, 2013 09:29 PM
Jason6969
May 25, 2008 08:39 PM
herrfixit
May 10, 2006 08:04 PM
LxMan1
Aug 5, 2002 04:09 PM
Dan Grimmer
Dec 30, 1999 07:54 AM
