Ok guys I need some help. My alarm web sight can't give me a straight answer so heres the question.
This is for our F350 7.3, with Ford factory remote lock/unlock.
Installing a Compustar 2WSS-AS remote start alarm. One of the alarm connectiors is for the glow to start signal needed for the remote start.
The alarm guys can't seem to give me a straight answer. Here's what they described.
1. Glow wire is located on the 42 pin plug that is located directly under the air intake. This is the plug that is connected to the left hand valve cover directly under the intake pipe that connects to the turbo. They claim its a white wire. Well I found two white wires. Anyone no if this is the case and if so which one.
2. Another one claimed it was a wht/grn wire out of the same cluster, which connects to pin 8 on the PCM, left side firewall engine side.
3. Several claimed its a blck/pink behind the instrument cluster. (does this mean taking out the cluster to get too this.
Anyone here wired there own remote start in this truck, or have knowledge of it. Thanks
Since I have not installed a remote start I am confused as to which circuit you are looking for. Are you trying to find:
a. the Wait-to-start dash indicator wire
b. the glow plug hot +12v circuit wire (the one that makes the glow plug hot)
c. the wire that tells the PCM that the glow plugs are energized (basically the same as the +12v glow plug hot feed)
d. the wire form the PCM that controls the GPR and causes the GPR to actuate
The wire that tells the PCM the plugs are hot, in which the dash lite turns off. It's at this point the remote starter can be actuated.
Their are apparently a couple locations this can be found.
AFAIK there is no wire that tells the ECU that the glow plugs are hot. They are simply assumed hot after a set amount of time.
The way that my truck activates the glow plugs is when you turn the key on, one of the two small wires gets power all the time. The way the relay is commanded on is completion of the ground circuit through the ECU.
There is a 18 guage White/Light green wire that comes off of the GPR via a blue - 20 guage fusable link and connects to the PCM pin #8 (ECU) whenever the glow plugs are energized. This wire would feed +12v to the PCM only if the GPR was working and feeding +12v to the Glow Plugs. It would go to 0 volts when the GPR opened.
I have always assumed that this wire is feeding some info to the PCM but the WTS light does not correlate to the time that the glow plugs are on. The glow plugs can be on for as much as 2 minutes but the WTS light will not stay on for that long.
I think you may need to trace the "wait to start" wire from behind the cluster and tap into that somewhere convenient. That light is connected to the "timer" somehow and should give your remote start the signal (or absence of hot if you will) it needs to crank the engine after the delay. Sorry I don't have a wiring diagram for these trucks but somebody does.
Great idea except the instrument cluster is fed through a bus ribbon cable, and there is no way to trace just the light. Thanks for the info, that was my first idea.
That cable might go the a place you can tap into though. That's what my oversimplifying brain was trying to say. I don't know because i don't have a diagram for my truck but I sure ought to get one. That WTS light is getting a signal from somewhere. Somebody with a diagram might be able to get you close to where you can begin testing with a probe. Maybe at the connection on that ribbon cable. Good luck.
That's why my schematics are treating the instrument cluster as a 'mysterious black box' circuit and does not show the actual connections to the WTS led, just a general path from the PCM to the cluster.
It would be helpful to find out how your remote start's logic determines when to start the truck. If it has its own timer, then the PCM pin 8 would do the trick. If not, it may need to have the 12 volt drop from the WTS indicator.
Yeah, I think it would make sense that any after market remote starter (for the PSD) would have it's own 30-45 second delay and then just go into cranking after it energized the GPs. I know there are several folks on this forum who have installed or had one installed. Hopefully they will happen along soon.
If i understand your original post correctly i would go with Guzzle's idea
and connect to the terminal at the GPR that is running to the GP's. I believe what your looking for is a 12vdc signal that tells your remote starter computer the GP's have been activated and i'm going to WAIT until the signal goes away(once the PCM shuts off the GP's) to start the vehicle. This is typically 90 seconds but can run up to two minutes max in the GP on/off cycle.
Is this wire looking for +12vdc(+ or - 2volts) to activate a commmand for the remote starter to wait for the glow plug cycle to complete?
Nut
GUZZLE92, Thanks for this tip. Yes thats the wire. Runs 12v+ and then shuts off and the wts lite stays on about 10-15 seconds. I timed the wire multiple times and it was consistent at 1.02 minutes. (Southern California at about 200' sea level) If I am not mistaken I believe that the wait time correlates to temp, and altitude.
Is this a GPCM on an Excursion? Or is it a SD?
Nut
