steering stop adjustment
Old Apr 14, 2006 | 09:35 PM
abe's Avatar
abe
Just got m '54 F-100 back from the shop. Had new king pins put in, didn't have time to do it myself...
Makes a world of difference in the steering. With my rebuilt steering box and now the kingpins, it really steers easy, even with the radial tires. I would recommend anyone that is contemplating putting in a modern power steering setup drive someone's truck with all the straight axle parts rebuilt or replaced.
Anyhow my question is this: The truck does not turn as sharp as it should. These old trucks were known for the sharp turning radius. What do I need to do? The shop manual says the steering stop adjustment is 2 1/16 left and 2 1/16 right. Did the mechanic not put the king pins in right? or adjust them right? What shall I tell the mechanic? Is it a simple matter to fix this?
I am not able to cut into my garage or parking spaces like I used to...
thanks,
abe
Old Apr 14, 2006 | 10:44 PM
Brian_B's Avatar
Brian_B
I believe there is a bolt on each side near the tie rod ends that are the stops? Perhaps the measurement is a distance from something?
On a side note: Do you know what they used for fluid on the steering box when they rebuilt it?
Old Apr 15, 2006 | 09:41 AM
DonMckay's Avatar
DonMckay
Abe,
Check that they cut the end off the bolt that holds the King pin in.
If the bolt is sticking out too far this will act as a steering stop. just my thoughts though I may be rambling.
Don
Old Apr 15, 2006 | 10:29 AM
abe's Avatar
abe
Don,
That makes a lot of sense! I will check it out.
Thanks!
abe
Old Apr 15, 2006 | 09:11 PM
abe's Avatar
abe
Found the problem, I think. It happens when I cut to the left. The end of the bolt on the left end of the tie rod is sticking up too high and it hits the spindle arm on the left side. Either the bolt was pointing down before the king pins were replaced or it didn't hit before. I also had the front spring bushings replaced. This may have changed things also. Should be an easy fix.
abe
Old Apr 16, 2006 | 08:28 PM
DonMckay's Avatar
DonMckay
Glad you found it.You should be good to go now.
Don
Old Apr 17, 2006 | 10:29 AM
Scott123's Avatar
Scott123
Thanks for that info. Not sure if it will pertain to my '51, but it turns real sharp to the right but not nearly as sharp to the left. I thought maybe the pitman arm was not on the steering box right, but it's splined so that if I take it off and turn it I have to turn a full 1/4 turn, by then I figured it'd cut too far left instead. Just need time to lay underneath it and stare at it for a while I think.
Scott
Old Apr 17, 2006 | 11:36 AM
52merc's Avatar
52merc
My 52 M1 is the same way - i think this is intentional to prevent the back edge of the driver side tire from rubbing on the drag link when turning left.
Mike
Old Apr 17, 2006 | 12:30 PM
abe's Avatar
abe
That's what I did. got on the creeper and laid underneath the truck with the wheels straight and then cut left and right and stared at all the parts. I am not an expert on '48-'52 however. That may be a feature that they improved on '53 model and up. They were designed to have the same turning radius both left and right.
abe
Old Apr 18, 2006 | 08:03 PM
tip49's Avatar
tip49
MII Steering
Sorry to highjack this thread but how does one limit the steering travel using the after market MII IFS ?
Tom
Kongerup
Sep 13, 2020 09:26 PM
BadDogKuzz
15
Dec 27, 2016 08:39 PM
MIKEDEL
May 5, 2016 08:22 PM
Kongerup
Jan 4, 2016 06:35 PM
abyars111
33
Jul 10, 2014 02:15 AM
