83 F100 Headlights problem
Old Apr 14, 2006 | 07:02 PM
g_dawlton's Avatar
g_dawlton
What's the problem? They don't work. All of the other lights work fine. So, I went looking under the hood for some form of a headlights relay - nothing. I read in the forums that the dash bezel comes off after removal of ***** where a lock nut is found that'll release the light-switch. The forum said the switch is internally fused. Any ideas beyond what I've stumbled upon??? Thanks,
Greg
Old Apr 14, 2006 | 07:39 PM
Rosie's Avatar
Rosie
The headlight switch has a built in circutbreaker. It could be the circutbreaker in the switch is defective in that it won't reset. It also could be the connections on the headlight. The back of the headlight is a three prong socket. Take the socket off the headlight and look at the blade connectors on the headlight. Clean them with some fine sandpaper and clean the socket also. Sometimes just pushing the socket on and off of the headlight will clean up the socket. I hope this helps. I have a '80 F100 and the passengers headlight was always dim even after replacing the headlight. Found out the socket was dirty inside and not making a good connection.
Old Apr 14, 2006 | 07:41 PM
g_dawlton's Avatar
g_dawlton
Rosie - Thank you, I'll have a look.
Greg
Old Apr 22, 2006 | 01:20 PM
g_dawlton's Avatar
g_dawlton
Headlights problem resolved
All,
Just for what it's worth, it turns out the floor-mounted headlight dimmer-switch was the cause. I asked a couple of guys that I work with, and in unison they both said dimmer-switch. I hope this info might help someone else out.
Old Apr 22, 2006 | 04:03 PM
sierraben's Avatar
sierraben
They (high beam floor mounted switch) do tend to stick inbetween the high and low beam position.
My does once in a while.
Old Apr 22, 2006 | 10:19 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Also of note to headlights, but not related to the general problem, ... My truck has a tendency for the headlamp circut breaker to activate when it gets foggy or humidity is very high. Packing the headlamp sockets with white lithium grease solved this problem. Condensation was getting into the plugs causing a short at the headlamps. The white lithium grease sealed the condensation out.
Old Apr 23, 2006 | 12:49 AM
sierraben's Avatar
sierraben
81-F-150-Explorer, Foggy? You just mentioned S.F.'s official weather.
The only problem I ever had with headlamps is when I was losing my leftside headlamp every few months.
Found out it was a bad leftside radius arm bushing.
Old Apr 23, 2006 | 06:40 AM
srercrcr's Avatar
srercrcr
My 83 came from the factory with the white grease in the sockets. After many years in S Texas heat it gets a little thick.
mustangpt
Apr 22, 2015 09:59 PM
F600greg
Large Truck
Mar 26, 2014 02:59 AM
Greg M-47
Aug 30, 2013 10:13 AM
grm61
19
Jan 31, 2009 10:00 PM
apbtpetey
Electrical Systems/Wiring
Dec 1, 2008 02:18 PM
