Sponsored by: Real Truck
What is this? Under dash.
Old Apr 13, 2006 | 10:48 PM
Shepard's Avatar
Shepard
Up under the dash, behind the fuse panel, right up against the parking brake is a rectangular metal box, partially covered with plastic. Anyone able to tell me what this is?
Thanks!
Old Apr 13, 2006 | 11:00 PM
n578md's Avatar
n578md
The Powertrain Control Module. (EEC-V)
Old Apr 13, 2006 | 11:10 PM
Shepard's Avatar
Shepard
I am not sure exactly what that does, but here is my question. It has two tabs with holes on the plastic covering the metal. I want to use those holes to bolt a small axillary buss fuse block there to wire in a few additional power supplies. I can't think of any reason why this would be a bad idea since the tabs are unused and it would not compromise the module, but just want to check.
Old Apr 13, 2006 | 11:31 PM
n578md's Avatar
n578md
The PCM runs the engine and transmission. As long as you're not drilling into the PCM itself, why not. I don't think you'll mess up anything or knock anything loose since its 104-pin connector on the other side of the firewall is actually bolted secure into the PCM.
Old Apr 14, 2006 | 12:19 AM
Shepard's Avatar
Shepard
Amazing! Such a big job in such a little box. No drilling, the tabs with the hole are already there on mine.
Thanks for the replies!
BDMartin
Oct 21, 2013 07:52 AM
mxdad33
19
Sep 17, 2012 06:37 PM
jetfixer
Electrical Systems/Wiring
Dec 4, 2007 12:08 PM
1bad66
Nov 14, 2005 11:22 PM
jandblott
Jul 19, 2005 07:29 PM
