need help with cruise control
the control modules that i know about are -- ECU: kick panel on passenger (sometimes driver?) side up front. CC or ABS(?): on the driver's inner fender and one behind the kick panel behind the driver's side seat between front/rear seats. I haven't looked at the others besides the ECU to know which is which.
Does your horn work?
Have you got a wiring diagram & voltmeter so you can do some testing??
Check it out at www.helminc.com
About 20 bucks.
There are lots of resources -- I'm sure you could Google 'em as well. Never really thought about local libraries -- I guess because the one closest to me is about the size of a double wide trailer house... that, and I haven't been to a library and actually researched anything that way in YEARS
1- There's a vacuum line that goes to the brake pedal under the dash, that kills any vacuum in the cruise servo unit, which expedites the cruise control system's disengagement when the brake pedal is applied. Make sure that hose hasn't developed cracks or separated from the mechanical valve that interacts with the brake pedal lever.
2A- If the transmission is manual, look for the switch on the clutch pedal lever. It's on the back side, making contact with the lever when the clutch pedal is released. Normally, the switch senses the slightest pressure on that pedal so as to electronically disengage the Cruise Control quickly. However, if that switch has loosened up from its fixture, it might be closed even when the clutch is NOT disengaged. Since it's ONLY used for the Cruise system, nothing else would be affected.
2B- If the transmission is automatic, usually a Neutral sense switch on it is used to deactivate the Cruise Control system. Not being familiar enough with the automatics, I can't say whether the switch closes or opens when the transmission is put in Neutral. If it opens, then check for loose wiring or connection(s) at that switch, or a bad switch. If it closes, and it's only one wire, then the signal for "Neutral" is 'Ground'. So, look for shorts to ground in that circuit. If it closes, and there are two wires, try disconnecting the switch. If the cruise control functions normally, replace the switch ASAP. Leaving it disconnected could result in engine damage from overrevving, not to mention possible safety hazards.
3- The main brake light switch is also used to electronically disengage the Cruise Control as soon as the brake lights are lit. If that switch has gotten loose, or perhaps the brake pedal is bouncing enough while driving (ever see a car ahead of you with the brake lights flickering?), it will prevent the Cruise control from staying on. BTW, if any fancy lighting or other gadgets have been added to the brake light circuitry, it could be adversely interacting with the Cruise Control's defeat logic.
4- If your Park Brake warning indicator bulb is burned out, it's possible the switch that lights that bulb is still closed constantly (or momentarily) without you being aware of it. Some Cruise Control systems check the status of the Park Brake, and if it's engaged, the Cruise will be shut down.
Hope this helps!
(2A) uhhhh.... the clutch pedal SAFETY interlock switch might be piggy-backed and have two sets of contact for both the starting circuit and the cruise control.... but the main reason for a switch on the clutch pedal is so that you don't run your rig into something if you hit the starter with the tranny in gear... IF you forget to push in the clutch.
(2B) The neutral safety interlock may be like the clutch interlock -- piggybacked to disengage both start circuit and c/c as well....
(3) see comment (1)
(4) Yes, this is a valid option on some c/c's.
A Joe-neric troubleshooting chart:
http://www.autozone.com/servlet/UiBr...3d800f9511.jsp
