Bronco II Ford Bronco II
84 valve train problem
Old Apr 20, 2006 | 01:20 PM
50woodie's Avatar
50woodie
The valve lifter push rod adjuster keeps loosening up on my 2.8liter bronco II.
Engines I have worked on in the past had a set screw to keep the adjuster from turning. Am I missing something or is loctite or silicone an option to keep it from turning?
Old Apr 20, 2006 | 05:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 24, 2006 | 04:35 PM
Hooked-on-4WD's Avatar
Hooked-on-4WD
The valve adjusters on the 2.8L and 2.9L are adjusted using an ordinary screwdriver, and then are secured from turning with a (12mm wrench?) locking nuts. The nuts require relatively little torque, only about 8 ft/lbs because the thread pitch is so fine (or shallow). Much higher and there's the risk of stripping out the threads on the rocker. If the locknut won't stay tightened, or loosens after running for a while, the problem rocker arm(s) and its adjuster may need to be replaced.
