Kinked air filter box hose?
Last Saturday I replaced my stock air filter with an AIRAID unit (still not sure if it was worth it).
I noticed the approx. 2" dia. rubber hose coming out of the front of the airbox has a noticeable restriction where it makes a sharp left 90 along the front support. It's not kinked shut, but it definitely ain't round. Is this normal?
BTW, this is on an '03 6.0 250.
IMO it is best to leave the stock intake on the truck. It is a good design and the donaldson filter is the best one for the truck. There are lots of threads on here about it. I don't believe the rubber hose on mine is kinked at all but I will take a look after work. As far as gettng that filter box out, it is a pain. I usually just unhook the MAF sensor and the rubber hose that is attached and then loosen the hose clamp on the back of it before the turbo and then I pull the whole thing out at once. This only takes a minute longer and it is sooooooooooo much easier. It takes me about 5 minutes to pull the whole thing out.
That's what I ended up doing to mine, too. It made it much easier to remove in the tight confines of that engine bay.
Concerning the Airaid filter, I have not noticed any difference in performance or MPG, so I may go back to the OEM filter.
That intake hose (it's the rubber top one that goes to the left fender IIRC) on mine is definitely tight!
Realslowww
01-05-2017 04:49 PM
cstanley44
09-03-2016 11:52 PM
PapaBearYuma
04-15-2012 06:00 PM
