hutch mod ?
Old Apr 12, 2006 | 08:19 PM
luvemhot's Avatar
luvemhot
hutch mod ?
i have everything for to do it and have one last question ( I hope). When I get rid of the coupling's. Do i get rid of both of them?
thanks
Keith
Old Apr 12, 2006 | 08:52 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Which both do you mean? You will want to get rid of both the pressure fittings on the feed line. The one on the tank and the one at the intake of the fuel pump....but it is not necessary to delete the fitting on the return line at the tank.
Old Apr 12, 2006 | 08:58 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
DO NOT disturb the one with the smaller pipe coming out of the tank. that is the return line, and it's working under pressure. the quick disconnects are designed to be used under pressure (return) not supply (vacuum). so leave the small one intact you will be using it. at the inlet of the pump, i smashed the connection with a pair of pliers and then pushed the hose off of the coupler. it worked easy.
Old Apr 12, 2006 | 09:06 PM
luvemhot's Avatar
luvemhot
I think i got it thanks
Keith
Old Apr 12, 2006 | 09:10 PM
luvemhot's Avatar
luvemhot
will i need a special tool to remove the fuel lines?
Old Apr 12, 2006 | 09:17 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yes. Ford A/C line fittings. A plastic set from Autozone costs $10 and works great.
Old Apr 12, 2006 | 10:35 PM
jtharvey's Avatar
jtharvey
I discovered that the hard way while changing a fuel pump. It was dark, cold, and almost time for the parts store to close. Luckily I made it with about 10 min before they closed. Used the same set for the pre-pump mod.
Old Apr 12, 2006 | 10:39 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Yes, I just pulled mine down this evening and the disconnect makes it a piece of cake. The same tool worked for both fittings.
Old Apr 13, 2006 | 02:09 AM
ryaneverk2's Avatar
ryaneverk2
It sounds like Kris was able to do it with just pliers... Or Kris were you talking about something else, and still needed to use the Ford A/C line tool?
Old Apr 13, 2006 | 06:59 AM
Rich in CO's Avatar
Rich in CO
I just did the in tank mod last week end and I re-placed both QC's on the tank & on the lines on the frame? I'm looking at issues down the road by changing out the QC on the return lines?
Old Apr 13, 2006 | 07:35 AM
mueckster's Avatar
mueckster
There shouldn't be any problems as long as the hose clamps stay tight. Might be a good idea to check for leaks once in a while and retighten them occasionally.
Lincoln77
17
Jun 1, 2017 06:11 AM
Bruinzfan
Mar 30, 2014 10:26 PM
keith bowen
New Member Introductions
Jul 15, 2007 08:44 PM
fkeitht37
20
Jan 24, 2006 03:28 PM
