transmission question
Old Apr 11, 2006 | 07:21 PM
zzzz944's Avatar
zzzz944
I have a 1999, f250, 7.3 diesel, 4R100 automatic, 4X4, that seems to be shifting into overdrive almost to fast. It also sometimes shutters a little when going into overdrive. I have 56,000 miles on it now and had the transmission flushed at 26,000 miles. I read in the forum that changing a transmission solenoid valve may solve the shifting problems. does any one have more info on what and where the solenoid valve is or any other ideas on this problem.
Thanks.
Old Apr 11, 2006 | 07:33 PM
Kwikkordead's Avatar
Kwikkordead
I recommend calling Brian and asking him. From what I've heard here on FTE he's one of the best.
http://www.brianstruckshop.com/
BareBackJake knows someone as well who is just as good
(I think) www.jwtt.com
Old Apr 11, 2006 | 08:38 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Thanks.
Welcome to Ford Truck Enthusiasts and the diesel forums.
What type of fluid was used when it was flushed? Your tranny calls for regular old Mercon, and not the more popular Mercon V...or any other multi-use fluid.
Does it make any noise...like a rattle while at idle?
Old Apr 12, 2006 | 05:28 PM
zzzz944's Avatar
zzzz944
Last time the tranny fluid was changed it was regular mercon. It does make a rattling noise when idling but it always made that noise since I bought it and that is when I had the fluid changed.
Old Apr 12, 2006 | 07:49 PM
Muktown's Avatar
Muktown
sounds like a torque converter problem
Old Apr 12, 2006 | 08:19 PM
barebackjake's Avatar
barebackjake
kwik you got it right....actually just got off the phone with jon
Old Apr 12, 2006 | 08:47 PM
cookie88's Avatar
cookie88
FTE Emeritus
That's what I'm thinking too.
Old Apr 12, 2006 | 09:15 PM
Muktown's Avatar
Muktown
Scott wasnt that a problem in 99 or am i thinking of something else?
Old Apr 12, 2006 | 09:30 PM
cookie88's Avatar
cookie88
FTE Emeritus
Yep. The coast clutch problem was mainly in the 01 model trucks, but a rattly torque converter can get anybody.
