Duraspark II troubles
Old Apr 11, 2006 | 04:23 PM
big hoss 29's Avatar
big hoss 29
Hey there! My 86 F-250 with a Duraspark II ignition and a 460 died on me last night. I replaced the ignition module with a Motorcraft unit this morning because I wasn't getting any spark. She started right up, it ran a little rough, but it eventually smoothed out. As I was driving home, the damn thing died on me like someone turned off a switch and I couldn't get it to fire up again. I had no spark from the coil. I got it towed home and just out of curiosity, I tried to start it and it fired right up! Again, it ran a little rough, but it smoothed out after 5 minutes. It has a new distributor in it, all wires are in good shape and the motor was rebuilt back in October. Could it be the stator in the distributor?
What is going on?
Old Apr 11, 2006 | 08:18 PM
Franklin2's Avatar
Franklin2
Check the voltage at the + terminal of the coil with the engine running. If it is 12 volts, then someone has done a re-wire, and the resistor is no longer in the circuit. This can make the coil and the module overheat.
Old May 12, 2006 | 09:30 PM
1ford1's Avatar
1ford1
hello, I am having the same problem with my 77. The voltage at the coil is 12v. What should the voltage be? Any suggestions how to correct? Possibly an inline resistor?
Old May 12, 2006 | 09:46 PM
thelonerangerxlt's Avatar
thelonerangerxlt
1Ford1, the voltage should be about 7-8v after going through a resistor wire (located under the dash). The easiest thing to fix it would be to mount an external resistor on the firewall, wired in series to the coil.
Old May 12, 2006 | 10:32 PM
big hoss 29
Just to let y'all know, I got the problem fixed. It turned out to be the pickup assembly in the distributor. I changed it and she purrs like an angry kitten.
Old May 13, 2006 | 01:24 PM
Franklin2's Avatar
Franklin2
Thanks for writing back.
Old May 13, 2006 | 04:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
Before anyone replaces parts, -most parts stores have testing equipment for the ignition system components. The testers work VERY well, so use them. It is easier than running thru the whole manual diagnostic tests listed in the manuals. Unfortunately if the modules test good on the store testers the diagnostic routines must be followed.
Old May 13, 2006 | 08:07 PM
Franklin2's Avatar
Franklin2
Also the part failure is sometimes heat related, so it may not show up on their tester. If it's a hot day, I put the module to be tested on the dash in the hot sun while I am taking it to be tested.
Old May 15, 2006 | 09:16 PM
Greywolf's Avatar
Greywolf
The silver lining in this cloud is that parts stores do not charge anything to test your components. How can you beat a deal like that?
tkisling
17
Dec 22, 2016 10:45 PM
lowridaz22
Nov 8, 2015 11:11 PM
79F-1504x4
May 28, 2010 09:39 PM
BobcatGuy
Feb 19, 2007 10:41 AM
jwtaylor
43
Nov 23, 2004 09:30 AM
