backwards driveshaft?
Old Apr 11, 2006 | 04:00 AM
oldblue31's Avatar
oldblue31
Red face backwards driveshaft?
Here's a silly one. I've seen some driveshafts with the slip yoke at the axle and some with it at the transfercase. Which way should it be?Also I don't have it on my highboy but I've seen advertised a trasfercase brace. Was this a stock part?
Old Apr 11, 2006 | 07:19 AM
fejunky's Avatar
fejunky
I'm pretty sure that the slip yolk should be at the transfer case, I've never ever seen them any other way, you may have seen a custom driveline someone had made. As far as the brace, my highboy does not have one either.
Old Apr 11, 2006 | 07:58 AM
4fords's Avatar
4fords
I had a 79 F150 4x4 short box that had the slip yoke at the rear axel. The front of the driveshaft had a cv joint ( I think thats what it was called) where it hooked up to the t-case. I was told that most if not all short boxes and broncos had this setup due to the short wheel base and the increase angle of the drive shaft. The cv joint allowed for extra articulation of the drive shaft. The first time I saw it I thought it was in backwards.
Old Apr 11, 2006 | 07:59 AM
garypettengill's Avatar
garypettengill
It depends on the vehicle. According to the Ford chassis manual for my '77 the slip yoke is installed at the axel end of the shaft. This is for F100, F150, F250 (4X4) and Bronco.
Old Apr 11, 2006 | 10:54 AM
fordraceboy's Avatar
fordraceboy
i run mine with the slip yokes by the t-case. i figure the higher up the less chance of them getting hit. I believe the 3 inch tube is stronger than the necked down part... JMO
bigric
Jan 11, 2012 10:09 AM
79f100custom_93
Feb 15, 2011 07:39 AM
UrbanRedneckKid
1983 - 2012 Ranger & B-Series
Mar 14, 2008 09:40 AM
JDMick
Aug 21, 2004 09:37 PM
