First time inserting a picture on this post. It's a picture of the Clifford intake manifold and EFI headers on my work bench. I was fitting the manifolds with a die grinder to make sure they fit together. Some modifications were in order. Hope this works.
Ok. Who knows the secret hand shake on how to post pictures on this site? I know it's so e-z it will be stupid, but it's not like other e-mails that I have used. Maybe this will help. I took pictures of my 300 I6 as I was installing the Clifford intake and EFI exhaust. It shows how I matched up the ports with a die grinder, found a way to align the manifolds onto the block, interferance issues, too much space between studs and flanges. ect. Also a way to mount a big honkin K&N filter in a van because of limited space. Plus a trick GM HEI dist bolt on assy. The van runs great and it's not even dialed in yet. I got some more tricks up my sleeve. So, any help out there?
Look for a little box near the bottom of the page called "Posting Rules" and then click on "IMG code is On," hopefully that'll explain it.
You'll have to upload the picture to a photosharing site like photobucket.com first, then determine the image's URL and use the IMG tags to embed it into your post.
Thanks for the info nss. I have never found the posting rules, anywhere on this site. I did a search for posting rules. Results were, "Can a diesel engine really run on vegetable oil?" Not really sure what is going on, but it might have some thing to do about money. It says it a free site, but I have my doughts. I don't have a sort option. I can't see all the Galleries. Hey, I just went to the bottom of this page and I found the posting rules here! GRRRRRRRRR Why do I think that is a lame place..... I guess I will look at it now. Ok. Found the box you mentionend. Don't have that much time to burn right now. Thanks any way nss. Just a true gear head at heart here. Hey! I don't give up e-z. I don't want to write software code. I want to insert a frickin picture. There has to be a e-zer way. I guess I need to go chill out. cya 40 min of my life that I will never get back.
