Changing air filters
Old Apr 13, 2006 | 05:50 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
also check with dealer about this. Possibly could void warranty. Check to be sure. Hate to do something that would void a 100K warranty.
Old Apr 13, 2006 | 11:31 AM
thelogster's Avatar
thelogster
Don't do it. The K&N flows better because is less restrictive -- and the trade-off is it does not filter as well. The stock filter from Donaldson stops 99.99% down to 1 micron. Run in the same environment, if the stock filter let through .1 gram, here is what gets through filters at other efficiency levels.
<LI> 95% efficiency -- 50 grams
<LI>99.0% efficiency -- 10 grams
<LI> 99.9% efficiency -- 1 gram
<LI> 99.99% efficiency -- .1 gram
K&N is around a 96% filter. You'd be letting a lot more junk through to your engine and putting your warranty at risk, as other posters mentioned.
Old Apr 13, 2006 | 06:57 PM
X GM GUY's Avatar
X GM GUY
Another thing to remember is their is only a minimal HP gain with a K&N and it is only at redline. I think you will find posts, with dyno results, this somewhere on the site.
Old Apr 13, 2006 | 07:29 PM
Sark's Avatar
Sark
Thumbs up Changing 6.0L Diesel Air Filters
Originally Posted by tvsjr
"6.0L Power Stroke air filter removal" Go to www.forddoctorsdts.com & they say they have a better way to replace the air filter. I'm going to try it here shorty.
Old Apr 13, 2006 | 09:41 PM
phish555's Avatar
phish555
Thanks guys, I will stick with what Ive got.
Phish555
06 F250 6.0 SuperDuty
Old Apr 26, 2007 | 11:47 AM
hope31's Avatar
hope31
You really should not rely on visually inspecting your filter to determine if it needs to be replaced. A dirty air filter filters better than a clean one.
Old Apr 26, 2007 | 12:31 PM
msgtg's Avatar
msgtg
Guys, did I miss something? I've got an 03 6.0 and about two weeks ago I replied to some guys post about the air filter.
Unless I'm really losing it, my manual said to inspect regularly but the replacement interval was at 60K.
I've got 42K on mine now...the gauge hasn't moved at all. I've already bought my replacement filter (a Motorcraft) and am just waiting for the milage to roll up.
Old Apr 26, 2007 | 12:44 PM
blackhat620's Avatar
blackhat620
[QUOTE=msgtg]Guys, did I miss something? I've got an 03 6.0 and about two weeks ago I replied to some guys post about the air filter.
Unless I'm really losing it, my manual said to inspect regularly but the replacement interval was at 60K.[QUOTE]
The First printing of the Diesel Supplement manaual for the 2003 said to change the air filter at 60k on page 52 and to change the air filter based on the filter restriction gauge at the top of page 7.
ALL other printings of the Diesel Supplement manual to date (including the Second printing of the 2003 manual) say to Only change the air filter when the filter restriction gauge indicates.
You can change at 60k if you want, but the filter minder is accurate, is the way to determine air filter change interval per FMC and is IMO the best indicator of when to change the air filter.
Hope this helps
Hope this helps
Old Apr 26, 2007 | 02:10 PM
msgtg's Avatar
msgtg
Thanks blackhat...I was concerned the senior moment thing was happening again!
I'm comfortable using the filter minder. Even if someone has reset it, it should read the blockage and display.
I just wasn't sure why some of the guys were planning their change so much earlier based on the info I have.
Old Apr 26, 2007 | 03:14 PM
blackhat620
msgtg,
Nope no senior moment, just changes to clear up conflicting information during reprint.
Some guys don't feel comfortable using a filter minder as it is foreign to there way of thinking and so they change the air filter based on mileage, engine hours or looks. If the air filter is changed more often than the filter minder indicates, only negative effect is litening the wallet faster.
Old May 2, 2007 | 02:53 PM
post-man's Avatar
post-man
Pardon the dumb Q, but does the truck need to be running in order for the filter minder to work properly. Mine hasn't moved either in 25k miles .. light duty .. no real dust/dirt .. getting 16.5 mpg mix city/highway use ... no tune .. I'm not comfy either with filter minder ... also I did the zoodad mod to get increased airflow .. .
Old May 2, 2007 | 03:04 PM
Colorado-native's Avatar
Colorado-native
The filter minder is just a latching vacuum indicator so the engine does not have to be running for you to check the gauge. Take a good WOT run for the most accurate indication of air filter restriction.
  #28
blackhat620
post-man,
No the engine does not have to be running for the filter minder to register properly. 25K miles is not very many miles on the Donaldson Powercore filter, i have gone 40K miles with very little movement, and 80K is obtainable depending on how dusty the conditions are you drive in. The filter minder does work, but they don't move alot until the final stages of the filters useful life span and this is normal. Filter minders have been used for years on heavy trucks and off road equipment with great success.
Here is a link for more info
www.filterminder.com/hfmw_air.asp
Hope this helps
Old May 2, 2007 | 10:06 PM
  #29
stroke6.0's Avatar
stroke6.0
I put an Airaid filter in my stock housing. It was cheaper than the stock, $58, and flows alot more air. I have K&N filters in my other vehicles but they wanted to much for the 6.0 filter. The Airaid is washable and will probably be the last filter you buy. Don
Old May 2, 2007 | 11:42 PM
  #30
blackhat620
It flows more air because it has larger holes in the filtration media and therefore allows more dust and dirt to pass into the turbo and engine. You took off the best air filter and intake system for your truck and replaced it with a substandard air filtration product. In addition the Donaldson system flows more air than your 6.0PSD can use until you get to an extreme race motor with aftermarket injectors and turbos. The Donaldson filter is good for 60-80K miles depending on the dust conditions in your area. Only way to know when it is time to change the Donaldson filter is by the filter minder on the air box.
In addition if you have turbo problems FMC is known to take issue with aftermarket air filters and not warranty the failure.
Good luck
