c4 modulator vacuum routing
Old Apr 9, 2006 | 07:46 PM
maverick82's Avatar
maverick82
Question c4 modulator vacuum routing
any one know where the vacuum lines on the mod. go too. there is two of them.its a 73 with a holley. if it was one it would be a no-brainer to me but its got two. please help!
Old Apr 9, 2006 | 08:20 PM
slow-canoe's Avatar
slow-canoe
The modulator gets its vacuum from the intake manifold from under the throttle plate . What it does is as vacuum changes under differant loads it controls the shift points. The other vacuum port on the holley in the metering block is ported vacuum and that is above the throttle plate and only has vacuum to it as the throttle opens . It is usally for the advance on the distributor. hope this helps.
Old Apr 9, 2006 | 09:52 PM
kennethl6's Avatar
kennethl6
I think your talking about to two ports on the mod. valve. Just use the outer one (larger tube) and leave the other one open. That one was hooked to the EGR valve back in 73 but there's no need to run that one.
Old Apr 9, 2006 | 10:33 PM
maverick82's Avatar
maverick82
hey i appretiate it kenneth.
peace..
xjcamaro89
2004 - 2008 F150
463
Feb 13, 2026 05:07 AM
dtkkc
Sep 23, 2016 04:49 PM
Jkenosh
Aug 25, 2015 09:57 PM
jerryparks
Apr 23, 2015 04:13 PM
Gidde Up
Aug 4, 2003 06:52 PM
