difference in 8.8 rearends
Old Apr 9, 2006 | 07:17 PM
Danos-f150's Avatar
Danos-f150
my truck got t-boned the other day, and in the accident, my right rear axle broke and bent the axle tube, so, i figured i would take the rearend out of a parts truck of mine, it has rear abs as well but my truck is a 96, and the parts truck is a 89. so what im getting at is if the abs sensor is the same between the obd2 compared to the 89 without. AND also, i was thinking about putting rear discs in this truck and i still want to use the abs, will this work????? I thank everybody in advance for their input
Old Apr 10, 2006 | 04:06 AM
aurgathor's Avatar
aurgathor
If you got the sensor in the same place (top of pumpkin) they're te same.
ABS should still work with a disc, but you do need a proportioning valve.
Old Apr 10, 2006 | 12:16 PM
Danos-f150's Avatar
Danos-f150
Thank you Much
Ivan M.
Feb 6, 2009 11:12 AM
bengen
Apr 13, 2006 08:06 PM
72shadetree
1978 - 1996 Big Bronco
Jan 24, 2005 07:55 PM
MustangGT221
Nov 1, 2004 06:43 PM
Justin89
Nov 15, 2002 03:15 PM
