1978 - 1996 Big Bronco
90 rearend
Old Jan 24, 2005 | 03:40 PM
72shadetree's Avatar
72shadetree
90 rearend
i have a 90 with the 8.8 rear thats going bad.i have a 86 parts bronco for my sons 83.will the 9 in rearend from the 86 bolt in to the 90 and and will the brake lines/cables work thats on the 90.i know the 8.8 has abs but that can be left unhooked as it doesent work anyway.thanks for any help
Old Jan 24, 2005 | 04:16 PM
InkDawg's Avatar
InkDawg
See if your 8.8 has a VSS in it..its a plug sticking out of the top of the 8.8 pumpkin. If you have that then you would lose your speed'o I believe.
Old Jan 24, 2005 | 04:34 PM
RLKBOB's Avatar
RLKBOB
The plug on the 90 axle is just for rear abs. The VSS is on the x-fer case. Yup it'll work, you might have to change the driveshaft mounting to the rear end or on your driveshaft.
Old Jan 24, 2005 | 07:55 PM
72shadetree
ok thanks alot for your help
spooktn
1983 - 2012 Ranger & B-Series
Sep 4, 2016 10:29 PM
Queen Bicth
Apr 16, 2007 11:34 AM
oldhalftons
Jun 26, 2004 04:47 PM
Ranger 86
Aug 18, 2003 05:13 PM
snizzitch
Oct 19, 2001 05:01 PM
