top speed
Old Apr 13, 2006 | 12:06 AM
ymmv's Avatar
ymmv
I've kind of lost the plot of this thread, but one thing I noticed on a long haul into the desert last month is the GPS (accurate) was 5mph below the speedo in the X at an indicated 75mph and 10 mph below at a speed-limited 100mph. The X hits 100 mph like it has a lot more legs, but it's also chewing 10mpg to push the brick through the wind.
Anyway, at 75 on the speedo, it's doing 70 on the GPS straight-line and I've never gotten much over 90 on the GPS which I guess is a speed-limiter of some sort because it's hitting 100 indicated.
Your biggest risk at anything over about 60 mph is the springs throwing the thing into a roll-over. Long travel suspension is just not okay when the kinetic forces get stored up in the springs. And there's no way the cabin is strong enough to survive a roll-over in such a heavy vehicle.
Old Apr 13, 2006 | 12:14 AM
cumminpwr11's Avatar
cumminpwr11
Ymmv
Right on the mark. Just drive safe and within "your" ( and your vehicles) limits
Chris
Old Apr 13, 2006 | 05:23 PM
mudman00x's Avatar
mudman00x
top speed
well on the same road last night racing my buddies mustang ,not really racing but just seeing what i can get out of it he said 134 ! , i really didnt think it was that fast, gonna do it again with another buddies corvette just to be sure
Old Apr 13, 2006 | 05:34 PM
quietman's Avatar
quietman
Originally Posted by cumminpwr11
Sorry for the hijack. I just realized what we did.Chris
Me too!
Sorry...
On topic...I hit the limiter at 105 on the GPS, 100 indicated...
...no tuner...
...yet
_____________________
Quietman
www.roenation.com
2005 EXCURSION LIMITED Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein mono-gas shocks, Rancho Steering Stabilizer
Silverstars, BFG 295/75/16 AT KO's on Factory Mags
LANDYOT Generation II Radius Rods, Ford factory hood insulator
Old Apr 13, 2006 | 05:40 PM
ymmv's Avatar
ymmv
134?
What's the HP to push 134 mph? 500? 600hp?
Anyhootk, if a sleep .30 CD of a Porsche 911 can run 198mph with less than 400hp, I'd have to imagine a lot more neddies to push a truck/brick to 130mph+.
As for speedo vs GPS, it's all in the gearing and "revolutions per mile" of the tires. I have snow tires (Blizzaks) on and they might well be "shorter" than the factory stock wheels but I did run a GPS on a stock wheeled X and notice the same, distinct 5mph+ difference between the satellite and the speedometer. Who knows?
Old Apr 13, 2006 | 11:13 PM
Industrial_dude's Avatar
Industrial_dude
when I still had a stock suspension and tires I had the Ex at speeds of 130-140 with egts in the 1400's and boost at around 32-34, rpms were at redline. Unless my cousines BMW had an inaccurate speedometer, this is what his speedo was indicating. I was running the edge on level 5 with a sct stack tune.
Old Apr 13, 2006 | 11:44 PM
BFTExcursionV10's Avatar
BFTExcursionV10
I don't understand why people like to compare apples to oranges! Excursions are NOT made to race, although if enough work is done, you could make an X blow the doors off a cayenne in a straight away..... all it takes is time & money! I have a buddy with an '03 X 2WD. He swapped engines! (a lot of work, but well worth it!!) He swapped it with a big block 460 and bored it out along with a lot of other things, including his blower he just added! This thing is gonna be taken to the dyno soom, and we're looking at a lot of horse power. This X is lowered a little (not a fan of that)! I will get a picture up on here when he is completely done with the paint job! Its unbeleivable how fast he could get over 3 1/2 tons up to 60!!
An X is made to carry 8 adults comfortably while towing 10K (sometimes more) lbs. A Cayenne is made to carry..... what? two or three people at the most comfortably in an "small SUV" style and still be able to say "I drive a porshe!"
Old Apr 14, 2006 | 12:01 AM
ymmv's Avatar
ymmv
The Cayenne is hot.
I tend to agree the Cayenne and the Excursion are apples and oranges. I'd say the Excursion is not that much different to Baja racers of its era but it's hardly going to compare with the Cayenne in anything other than straight line acceleration.
Anyway, if you haven't driven a V8 Cayenne (the Turbo is no big deal, seriously) then give it a drive. It's awesome transport for four people and everything they can carry (or a couple of dogs) and it tows (with air suspension) 7700lbs and handles nicely. There's no option for a weight distributing hitch (it's a unitary chassis, so there's no frame ladder and rails to transfer the load forward) so it's pretty good but still a lightweight in Super Duty or Excursion company. But then again, at 100mph, it's barely starting to open up. It's quiet and it can compensate for driver mistakes right up to the limit. If you do take that test drive in a Cayenne and you like it except for the price, go drive the VW Touareg. Same machine, much less dollars and, for my tastes, a much more appealing overall product.
Anyhoot, I have the option to drive or own a Cayenne Turbo but still ended up with an Excursion diesel, much to the dismay (and repeated emails and phone calls) of the local Porsche shop where my company did most of its business. So it goes. If Mr Porsche gets around to restyling the Cayenne to be more appealing, if they improve the towing capacity (say up from 8000lb to 10,000lb) and figure out how to have a 1000lb tongue weight rating, then maybe do a long wheelbase version (for legroom, storage and straight-line stability) then I'd happily overlook some other niggling complaints and go with the brand I'd rather be driving. But for now, a Ford as crappy as it is in some respects is still just an unbeatable product in its class. If any other maker out there comes up with an SUV running a big turbo-diesel, towing 10,000lb and costing US$45K, I'll happily reconsider. : )
Old Apr 14, 2006 | 12:05 AM
RACERX7775's Avatar
RACERX7775
i hate to say it again, but my cayenne turbo will smoke ANY X!!!you say its unbelievable how fast he could get 3 1/2 tons up to 60? by the time he gets to 60, i'm at 90!!! my cayenne weighs alot less than my X ever will and with 450 hp, the suspension, wheels, brakes, makes it a AWD sports car...and being speed limited to 155, by the time i would even think about getting to that speed, the X would be so far back, you would think he gave up. lastly, i certainly am not bashing the X, i absolutely love mine, but you have to remember, the X was not built for speed and handeling, it was built for hauling cargo and towing...
Old Apr 14, 2006 | 02:07 AM
Industrial_dude
I bet Ill take a ferrari Enzo with my excursion on 40" tires bahahahah!!! you guys are funny get over your selves diesel excursions are quick and much powerful then the cayenne but the cayenne is FFast.
Old Apr 14, 2006 | 09:13 AM
BFTExcursionV10
1st of all when looking at a diesel, horse power is not what you are more interested in. Its the torque!
There's a quote out there "Someone always has something faster!" So don't be so sure that your "Porsche" thing will blow the doors off of "ANY X"! You are right for a stock X, but not "ANY X"! lol Its kind of like me saying "My Mustang is so fast after all the work I've done to it, it will blow the doors off of any other Mustang!" Thats wrong someone might have made on faster.
(Not trying to sound rude! Just saying things the way I've learned!)
Old Apr 14, 2006 | 09:51 AM
cumminpwr11
Racer,
Out here in Vegas, there is a F-350 crew cab long bed lifted on 38's. it has a twin turbo cummins in it, and it pulls high 11's, low 12's at the midnight mayhem.(RUN WHAT YOU BRUNG)
That will keep up it most 911's (we are talking 1/4 mile only here)
Last I checked a 350 weighed more than an Ex.
"True there is always something fast, but as long as I am fast than you thats all that matters!" Chris
Old Apr 14, 2006 | 04:38 PM
  #28
BFTExcursionV10
Cumminpwr,
That 350 sounds preety darn cool!!!!! Do you know the guy?
Racer, there are a lot of people with Camaros, Mustangs, and other models that will blow the doors of a Porshe without even trying!
by the way industrial dude,
NICE TRUCK!!!!!!!!!!!!!!!!!!!!! It's awsome! Did you do all the work yourself?
Old Apr 14, 2006 | 11:20 PM
  #29
Hello's Avatar
Hello
Ever since I got a flat because of the start of a tread separation, I've slowed down. My racing now is only done uphill, and around corners.
For the high speed stuff, I got my 427 Camaro.
Old Apr 15, 2006 | 01:14 AM
  #30
Industrial_dude
Cumminpwr,
hey thanks for the compliment Ive had 2 shops work on my truck the first shop did such a horrible job I had a more expensive shop fix their mistakes and that shop is Off Road Unlimited. Ever since Off Road Ulimited Re-did my truck I stopped breaking transfer cases, ring and pinions, and drive shafts. You get what you pay for.
