Offroad & 4x4
True Trac question
Old Apr 9, 2006 | 10:26 AM
99 Ford's Avatar
99 Ford
True Trac question
I just had a Detroit TrueTrac put in my stock 9.75 rear differential (99 F150 4x4)...sweet. TrueTracs have always performed well for me in Wranglers. Does anyone know of any problems or concerns with putting a TrueTrac in the stock 8.8 front differentials of the 1997-2003 F150s?
Thanks.
Old Apr 20, 2006 | 07:17 AM
99 Ford's Avatar
99 Ford
Is there a more appropriate forum location within this website to post this question?
Thanks.
Old Apr 20, 2006 | 07:25 AM
fishmanndotcom's Avatar
fishmanndotcom
this is a good place for it! we talk about lockers and axle setups very often.However i will not be able to help you as i know nothing about the True Tracs and even less about the newer F150's!
hopefully others will chime in!
-cutts-
Old Apr 20, 2006 | 07:44 AM
mark a.'s Avatar
mark a.
Mine didn't even make it 100 street miles before it broke.
Old Apr 20, 2006 | 09:37 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
is a true tra a clutch style limited slip similar to a trac lock? or is it the gear type?
Old Apr 20, 2006 | 04:18 PM
Amtek's Avatar
Amtek
Its a gear type.
Because the 8.8 front axle on the 99 F150 4x4 (exact same truck i have) works with a Center Axle Disconnect system, a True-Trac will cause your front drive shaft to spin all the time, which MAY cause premature wear or a little extra noise when you driving down the highway. It might affect gas mileage just by a hair since its just one more thing that spins when your driving. However it seems that many people dont seem to mind this and have had no problems.
How about an E-locker like the one Kubota is using? If you want max traction, go with a selectable locker. It has to be selectable for this type of front axle.
In fact, they have a video on their home page with an F-150 like ours equpped with E-lockers. http://www.traction.eaton.com/prod1.htm
Old Apr 21, 2006 | 08:31 AM
99 Ford's Avatar
99 Ford
Thank you very very much. I assume the Auburn ECTED http://www.auburngear.com/ featured in the April edition of Off-Road Adventures would operate in the same fashion as you described for the TrueTrac. If so, a selectable locker like the Eaton E-locker will be my choice. Thanks again.
Joel Cassell
Jan 12, 2016 09:29 PM
CTC01
Nov 19, 2014 11:44 AM
Gerby Dutchy
2009 - 2014 F150
Nov 14, 2014 01:54 PM
lasitter
Jun 13, 2014 12:32 PM
3fordasho
Apr 1, 2014 04:29 PM
