I have a 2002 Explorer 4WD that squeeks when going ever speed bumps. It doesn't squeek just going down the road. Probably not worth messing with but I was wondering if there was a easy fix?
Welcome to the club.. I have an '02 w/ the same problem... I've been told that it's probably just the crappy sway bar bushings... I had posted a question on the forum a while back as to where to find something other than the stock rubber bushings to put back in. Apparently, nobody knew (never got a response).. otherwise, I woulda bought some and put them in.
I have the same problem in my 99... When I bought it in 01, the rear buchings were replaced under recall and I have heard rumblings of bushing issues in Explorers over the years. Let us know if you find anything out... I'm tired of people looking at me like I drive a 73 Cadillac because I squeak so much going over speed bumps...
Slather some multipurpose in those frame bushings. The ones that the swaybar goes through. Wife's did the same 4 years ago. Really creaky especially when you hit those speed bumps straignt on.
It was multi-purpose. 5 years ago. Dealer did it. If worried about eating the rubber you could try some silicone o-ring grease.
I haven't had to pull the sway bar off since but I believe you should to grease them.
I do not know if the grease they used damaged the rubber bushings, just know they haven't moaned since then.
