Pyro reads 250 when I turn the key on (not start) and engine is cold
Installed pyro, boost, and trans gauges yesterday. The pyro seems to be wrong. I used the clamp style probe pre-turbo. Running down the highway at 70mph/1950rpms, pyro reads about 850 and 900.
Any ideers?
Thanks in advance.
Any ideers?
Thanks in advance.
well it definately seems that it is about 200 off, I usually run about 700 cruising no load on interstate, maybe lower been a while since i looked. Did you cut any of the RTD wiring? also check to make sure the connections are secure and have great continuity. I believe RTD probes read higher temps with increase of resistance. So if the connections are weak, it would through the gauge off. Then again, it might just be the gauge itself.
I didn't cut any of the wires. I have a lot of extra lead wire and they are connected with a screw and nut that came with the gauges and lead wire kit. I used the factory ground mount under the dash just to the right of the driver's leg area and for power I spliced into an ignition switched wire on the plug under the dash that isn't plugged into any thing. Do you think that plug not hooked to anything could be the problem? Oh, and all the screw/nut connections are covered with the high temp sleeves that came with the gauges. The first time I turned the key, it read 300. Now, this morning it reads 250...
I just went out and started the truck. Turned the key on, it read 250. Turned to start, during cranking gauge dropped to 100, jumped to 900 and settled to 500 at a cold idle. Somthing's up.
It sound as if your pyro is definately mis-calibrated. Could be due to some mishandling during shipping. I would start by contacting the vedor you purchased them from as see if you can get an exchange.
My autometer seems to be off by about 40º on the low end. During the fridged temps this winter, it would read 50º with the key turned to on and now with ambiant temps of 60º, it reads 100º with the engine off. I can live with that but I think 200º would be too much.
stick the probe in a cup of BOILING water. it should read approx 212*f. if not it is wrong (should read high, low means broken).
Lead length is relative, on iron/constantine TC the leads have to NOT be cut or it alters the readings.
More resistance will generally LOWER the temp indications on the meter. 1 ohm adjusts about 100 * f
Is it ok for the edges of the probe to be touching the sides of the hole? The directions didn't specifiy the whole size so I drilled it just big enough for it to fit.
Today while driving from the store I noticed it would flucuate down to what I would estimate to be the proper reading and then back up.
The thermocoupler isn't long enough to touch the other side of the pipe is it? When you say the hole is barely big enough for the probe, there isn't any way that it could be touching the pipe on the side and grounding out and thus giving a false reading when it does? Just a couple of thoughts.
Joe
Joe
Originally Posted by Orezona
I'm sure it isn't touching the other side, but I'm also sure it's touching the edge of the hole I drilled. Would it ground out on the sides of the probe?
Joe
I'm definately leaning toward a defective part. Which one I just don't know. I purchased the gauges and kits from DieselManor so I'm going to give them a call first thing in the morning. This gauge thing has been one pain after another. It took me three weeks just to get the right color of the pod, and it still isn't perfect, but close enough (didn't get the pod from dieselmanor). I checked the ground and it is solid.
What does your guy's/gals pyro do when the engine is cranking for start?
what a coincidence. I just installed my gauges this afternoon and was logging on to ask the same question.
My Pyro reads 100 when cold and my tranny reads about 120 when cold. I have autometer boost/pyro and trans.
I as well had an issue with mount color. I ordered grey and they sent me black but they didnt charge so I didnt get to upset. took me about 3 hours and 10 autoparts stores to find the right vinyl paint.
p.s. I drilled and tapped my pyro pre turbo.
