new disk brake kit
Old Apr 9, 2006 | 05:27 AM
army_guy25's Avatar
army_guy25
Question new disk brake kit
is there a KIT i can buy that has everything i need to covert front of my '72 from drum to disk? i mean everything spindles propoton valve rotors!!! everything! finding stuff around me is hard to find or when you do its been TRASHED!! in my opinion just buy it new!! THANKS
Old Apr 9, 2006 | 06:02 AM
jowilker's Avatar
jowilker
Yes, A 73-79 donor pickup. You will have Ford factory engineered parts that are inexpensive, easy to find anywhere, and bolt right up, perfect fit.
John
Old Apr 9, 2006 | 06:17 AM
banjopicker66's Avatar
banjopicker66
Yes, John is right, A donor truck, '73 - 79 will have everything. Of course,you will need to buy replaceable parts such as king pins, rotors, bearings, master cylinder and calipers, but those you have to buy no matter what. You will save a lot of money just on the core charges alone.
If you get a donor ruck, you can have options such as power steering and power brakes added - - and it all interchanges.
Old Apr 9, 2006 | 10:39 AM
1972ford_f-100's Avatar
1972ford_f-100
there is a company that makes a whole kit for the switch,but it cost like 800 bucks!
Old Apr 9, 2006 | 02:30 PM
lokeraz's Avatar
lokeraz
what parts do you need to do the swap? im thinking of doing it to my 67 from 8 lug to 5 and disks in the front
Old Apr 9, 2006 | 04:13 PM
army_guy25's Avatar
army_guy25
money is not an issue
Old Apr 9, 2006 | 09:52 PM
tonpartain's Avatar
tonpartain
If money is truely not an issue, then take a look at this kit...http://bossap.com/wsm/i-7282_65-72_front_disc_brake_conversion_kit_-_power_brakes.html. I chose to go to a junk yard, spend about two hours and $200, and get everything I needed.
Old Apr 11, 2006 | 03:05 PM
Franken-ford's Avatar
Franken-ford
that kit is pretty sanitary...if money wasn't an issue i would go with that. if it were me. that's a lot of coin though. Looks like a quicker install and all the parts are new or at least freshly reman'd.
not that there's anything wrong with 34 year old brake & suspension parts from the junkyard.
Old Apr 12, 2006 | 01:30 AM
patcat's Avatar
patcat
I purchased a 67 Ranger F250 Camper Special in decent condition w/ 4bbl and duals and a 1971 F250 Cmper Special w/390, air, and disk brakes for $1000 because the owner needed to move. I tried to sell the 71 on Craig's list to no avail. I think I was lucky! I like the idea of having a 390 block, spare c6 and everything needed for a disk brake conversion. I already robbed the behind the seat fuel tank to replace the leaking one in the 67. The problem is space. Where I live that is a valuable commodity so I am buying time with the 71 parts truck parked in a temporary location until I can figure out where to store it. I do have a question about the 352 in the 67. It has a 4bbl and cast iron intake that looks stock and it feels much stronger than a 1969 Ranger F100 360 2 barrell, single exhaust I also have. In the books I've looked in there is no mention of a 4 barrel for the 67 Ranger. Any idea of stock HP with this setup?
Also, How difficult is it to change to disk brakes?
Thanks,
Patcat
Old Apr 12, 2006 | 05:32 AM
jowilker's Avatar
jowilker
Pat, The trucks came with 2 barrels. Measure the stroke, someone may have put a 390 in the truck.
John
elramosjorge
29
Nov 11, 2016 04:05 AM
Jesses1999f250
Aug 19, 2016 07:46 PM
63' f100
Jun 29, 2009 12:22 AM
foxracing0934
Nov 15, 2008 05:31 PM
no164ford
Jan 26, 2007 03:07 PM
