Losing power, big time..
Old Apr 8, 2006 | 04:53 PM
71 Muddbugg's Avatar
71 Muddbugg
Haven't been here in a while, sorry guys been real busy.
I have a problem hoping you can walk me through it. 97 f-350 dually. 5 speed manual. No mods, just straight pipe. Runs great good enough power I think. Today my daughter and I were driving around town then decided to go out on the highway for a spring drive. Outside of town there is a hill with a good grade to it where you cross the river then back up again. Never had a problem pulling it in 5th until today.
Half way up I started to lose a bit of power. No big deal, give a little more peddle. Nothing happened. I turned around at the top of the hill and went back to town. Climbing the hill on the other side of the river, I have to shift down to 4th and continually lost power to where I went from 80km to 50km. Never had to shift on the hill before. When I got on the flat I went to 3rd gunned it not much there, shifted to 4th gunned 'er again still not much there.
I don't know enough about diesels to make any guesses but this really sucks because it is my work truck and my only source of transportation.
I need to know what to look at first and where to go from there.
Truck was warm, temp outside was 10C. Never noticed any noises or anything. I could hear the turbo 'whistle' as it spooled up like normal.
I don't get it, last week I pulled those same 2 hills with 3000lb on the deck and did it in 5th without a problem.
Air filter guage says its ok???
New fuel filter in Jan.
600km on oil.
Help, help, help!!!
Adam
Old Apr 8, 2006 | 05:45 PM
71 Muddbugg
I did some searching on here and tried a couple things, then I checked the cap on the fuel filter. I got a full turn with my hand! Probably the problem right there, sucking air. I went for a drive quick and it felt fine. Maybe that was all it was.
tjbeggs's Avatar
tjbeggs
check your air filter visual. maybe a mouse nest or something in there. the guage is not trustworthy. any check engine light?
Old Apr 8, 2006 | 06:26 PM
71 Muddbugg
Looked at filter, I think it need to be changed. Maybe a 6637 is in order???
Old Apr 8, 2006 | 06:29 PM
tjbeggs's Avatar
tjbeggs
Fuel Filter May Have Been The Problem
Old Apr 8, 2006 | 06:32 PM
tjbeggs's Avatar
tjbeggs
fuel filter may have been the problme but was it leaking fuel out? if not its may not have been but who knows give it a try and see what happens. still may have been letting air in but not fuel out.
Old Apr 9, 2006 | 04:32 PM
71 Muddbugg
Yeah, I think it was the fuel filter cap being loose. I wnt for a rip and everything is fine now. Seems to be better actually!
Old Apr 9, 2006 | 07:59 PM
tjbeggs's Avatar
tjbeggs
Great!! love the easy fixes. good thing you found it before going onto much more expensive stuff!
