4x4 binding
Old Apr 8, 2006 | 04:43 PM
jmizell49's Avatar
jmizell49
4x4 binding
I have a 2004 4x4 Screw Larait. When I am in 4 wheel drive and making a
turn, the truck wants to come to a binding halt. Like the breaks are on.
I'm not talking about a sharp turn either. My warranty is almost out and
was wondering if anyone is having this problem.
Old Apr 8, 2006 | 05:07 PM
WhëëlMå1's Avatar
WhëëlMå1
Might be a silly question, but what road/land surface does this happen on?
Old Apr 8, 2006 | 05:09 PM
jmizell49's Avatar
jmizell49
Ice, rain and dry pavement. Havn't tried mud yet.
Old Apr 8, 2006 | 05:13 PM
WhëëlMå1's Avatar
WhëëlMå1
"rain and dry pavement"
You use your 4x4 in rain, and on dry pavement? That will ruin your 4x4 system right quick. I dont know what gears you have, but ALL 4x4 setups have slightly staggered gearing (for example, 3.55 rear gears, 3.54 front gears). When you use this setup on tar, there is no give or slip, and nasty things happen. This is not a problem on snow or mud, because it is naturally slipperly, so the overdrive effect is negated. Do you drive in rain or on dry tar with 4x4 often??
Old Apr 8, 2006 | 05:50 PM
jmizell49's Avatar
jmizell49
No. This isn't my first 4x4. I have had the binding occur a couple times accidentally. After the binding occurred on ice, I decided to test a couple times on dry payment. Apparently, you can't turn a F150 that is in 4 wheel dr. My jeep will turn. My explorer would turn. My waggoneer would turn.
Old Apr 8, 2006 | 06:21 PM
96f150's Avatar
96f150
In your 4x4 supplement that comes with your truck, it specifically tells you not to use 4x4 on dry pavement. These are not AWD vehicles. AWD vehicles have a viscous clutch in the drivetrain to allow for speed differences that occur when turning and the like.
Old Apr 8, 2006 | 06:24 PM
ford390gashog's Avatar
ford390gashog
using that 4x4 system on that type of surface will ruin the components. Ice would be fine but i would not use it in the rain or on dry pavement.
Old Apr 8, 2006 | 06:38 PM
jmizell49's Avatar
jmizell49
Why did it bind and stop the truck while i was turning into a parking space
during an ice storm. Is that normal?
Old Apr 8, 2006 | 06:43 PM
WhëëlMå1's Avatar
WhëëlMå1
It could have been at that exact moment, you werent on a patch of ice. Have you taken it to the dealer for this concern at all before?
Old Apr 8, 2006 | 06:50 PM
jmizell49's Avatar
jmizell49
No. My warranty is fixing to expire and I thought I would ask the forum first.
Old Apr 9, 2006 | 09:32 PM
73mach1's Avatar
73mach1
where you in 4low or 4hi?
Old Apr 10, 2006 | 02:43 PM
exiled's Avatar
exiled
Why not in rain? i'm just curious. i dont use 4x4 on payment at all. but when it rains the oil off the road floats to the top making the road slick i did'nt think that it would hurt in 4h.
i have no problems turning my f150s. of corse i dont use 4x4 on the road neither. i have never needed to. i mainly use 4x4 to keep from tearing the ground up in the pasture on in the yard.
Old Apr 10, 2006 | 04:57 PM
WhëëlMå1's Avatar
WhëëlMå1
It is because of the staggered gearing I mentioned a few posts above. Also, it is not oil floating on the surface that causes rain to be slick, its the rain that causes rain to be slick. Whether you put a truck off the road due to a puddle, or slip and slide taking a corner, it is all varying degrees of hydroplaning. Back to the gearing, with the staggered gearing mentioned, the front end will actually spin faster, and 'drag' the rear end along...to a point. This is not noticed in the snow or mud, because of the constant slippage, so the bind is corrected. The static traction that tarmac provides is far greater than the other mediums, so there is no chance for the 4x4 system to unbind. This is done for safety in winter driving. It forces the vehicle to oversteer, giving greater confidence driving into slick winter corners and hills. It literally turns the vehicle into a puller momentarily, instead of the normal RWD pusher.
Old Apr 10, 2006 | 05:22 PM
4wdriver's Avatar
4wdriver
i live in central ny ,my driveway has snow all winter,and i noticed my truck(reg cab f150)also binds more so than my old truck.i only have 4000 miles,seems i'll have to pay more attention next winter if this isnt normal.
Old Apr 11, 2006 | 07:04 AM
jmizell49's Avatar
jmizell49
4 wheel high
