Coolant circulator/heater???!
Old Apr 8, 2006 | 04:38 PM
dools's Avatar
dools
Hey guys,
Working on the 76, 360. Its an Arizona truck but came to Alaska in 76. Noticed that it has a red cylindrical apperatus attached to the side of the engine compartment. Has an electrical plug in exiting through the grill and has two tubes coming out of it. The top tube has a Y connection into the tube that goes from the top of the engine to the heater. The other tube goes to the bottom of the engine to what appears to be the freeze plug.
Was going to take it off, as it appears to be an old school engine heater. Disconnected the top tube and its full of coolant. Stopped at that point.
Was wondering if any of you gents have ran into these or used them in the past? I've only had contact with the more modern engine heaters and would just as soon use a new one thats not quite so funk-tified.
Lemme know.
Thanks buddies, Dools
Old Apr 8, 2006 | 07:33 PM
fatherdoug's Avatar
fatherdoug
You are correct. It is a tank-type engine heater. It is (or was) used in place of the soft-plug type heater. My '74 ford had one installed as an aftermarket installation with good results, but it took up a lot of space.
Old Apr 8, 2006 | 07:59 PM
76supercab2's Avatar
76supercab2
We had one on our '76 when we lived in Alaska. Worked pretty well.
Old Apr 9, 2006 | 12:50 AM
dools's Avatar
dools
Yeah, so, evidently I was a little hasty in posting this. I relaxed and thought about it for a minute. Ofcourse its a tank heater! I wan't thinking. Tried it out, still works (Manufacture date of 1979). Seems to me like tank heaters are better, though you really dont see them too much these days......Anythoughts from the peanut gallery?
Old Apr 9, 2006 | 12:55 AM
ford390gashog's Avatar
ford390gashog
tank heaters work well but are not common today. if you do find them they will be $$$.
Old Apr 9, 2006 | 05:48 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Tank Heaters
Originally Posted by ford390gashog
Tank heaters work well but are not common today. if you do find them they will be $$$.
Tank heaters work very well and are still used today in the northern U.S. some even run on propane. But most on electricity, 110 Volts. I used them for years, when I lived in northern Minnesota.
Old Apr 9, 2006 | 07:23 PM
Hypoid's Avatar
Hypoid
They work relatively quick also, no need to leave them on all night. Living in the mid-west (not Alaska LOL) took about 30 minutes in 0 to teens temps. Hopefully you'll be able to find a wattage on the unit, they can get expensive if run all night.
Old Apr 9, 2006 | 08:33 PM
dools's Avatar
dools
Yeah I pulled it off the truck and cleaned theunit up. Kats brand, 120 watt
Pretty slick unit, got hot real fast. I think I'm liking it better than the pads.
Old Apr 9, 2006 | 10:14 PM
Hypoid's Avatar
Hypoid
120 Watts? That's about a light bulb under the hood. More likely there's another 0 on the end: Like running a hair dryer.
Old Apr 10, 2006 | 02:06 AM
dools's Avatar
dools
yeeeeaaaaah.........there could be another zero.........dont qoute me. It's been a long week end
Old Apr 10, 2006 | 12:06 PM
Mil1ion's Avatar
Mil1ion
The best heater is the flow heater system , this allows coolant to circulate through the block.
To use it properly at low expense, get yourself an outdoor electrical plug-in timer unit.
Depending on how cold it gets a maximum of 2 hours is enough to heat the block.
That will be a 1200 watt heater btw
guitar_199
1997 - 2003 F150
Jan 13, 2024 02:56 PM
Fixnstuff
Nov 12, 2018 11:23 AM
jumperbob
Dec 15, 2014 11:42 AM
PSDVirgil
Modular V10 (6.8l)
Nov 5, 2013 03:13 PM
gt250
Mar 11, 2007 08:24 AM
