lower pitman arm seal replacement
Old Apr 6, 2006 | 08:38 PM
cblu007's Avatar
cblu007
How do you go about replacing the lower pitman arm seal on a 1984 f-150. Do anyone have any diagrams of this part. Do you need any special; tools. A link to a web site would be great .
Old Apr 7, 2006 | 11:21 AM
fordtruggy's Avatar
fordtruggy
I dunno that you can.Mine went out and i was told to shell out over a hundred to get a new box.??
Old Apr 7, 2006 | 11:41 AM
cblu007's Avatar
cblu007
I already have the repair kit. But not sure what it entails to repair.
Old Apr 7, 2006 | 12:37 PM
fordtruggy's Avatar
fordtruggy
Oh,well hopefully someone will post a reply on how to do it.I had a spare box and just used that,but it would be nice to know.
Old Apr 7, 2006 | 02:29 PM
Pkupman82's Avatar
Pkupman82
Is it the grease seal on the tierod end or the seal on the steering gear box? If it is the gearbox leaking you might as well replace it, Id be willing to bet it has a good amount of wear and slop in it. The box is not hard to change, you will want an extra set of hands to help you get it bolted into the truck. I replaced mine last summer, the gf helped me we had it done in an hour. If you would rather replace the seal you will need to remove the pitman arm to gain access to it. Either way you go you will need a pitman arm puller type tool.
Big Norm
1997 - 2003 F150
Nov 15, 2014 08:53 AM
ljcandme
Aug 23, 2011 11:48 AM
dogranger
1983 - 2012 Ranger & B-Series
Jan 30, 2009 04:39 PM
zfifty
Dec 5, 2006 09:20 AM
hello?
Jul 31, 2005 12:58 PM
