I want to bid on these valve covers. Tell me if they're going to fit my 94 351W. I don't know if there's a difference between the older 351W and the one I have. I mean, it's just a valve cover.
nice, just what I was looking for. I'd go look on my own, but the truck is in a parking loat about 1/2 mile away. I'm on a college campus... Thank you sir
Find you a good used set from the salvage yard and send 'em off and have them plated. There's not that many aftermarket VC's for the EFI engines out there.
They should fit, they look very much like the stock ones except for the oil filler tube as mentioned above. The hole locations are the same as stock, so position wise they will work. You'll need a PCV grommet for the passenger side, and you'll either need an open element filter for the drivers side (illegal from an emissions stand point) or a push in breather with a hose nipple on it to connect to the existing crankcase breather filter (emissions legal option). I have the chrome ford motorsport valve covers on my 87, you might be able to see them in a picture or two in my gallery.
I'll take a look in your gallery. I think I decided I'm just going to sand the ones I have down to smooth metal, seal them up, and spray them a nice Ford blue.
