Does Your Speedometer Do This?
Old Oct 18, 2002 | 05:24 AM
jds1971's Avatar
jds1971
Old Oct 23, 2002 | 09:17 PM
Like M. Fords's Avatar
Like M. Fords
I asked this question about a year ago but got no replys. So I decided to take a picture to proove I am not some freak.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=9635&.jpg
It is not the best picture, so I hope you all can make it out. This spedometer is the original '70 F250. Assuming that the speedometer needle pivots somewhere between and behind the O & R in FORD; this truck has what appears to be a counter-balance for the red half of the speedometer dial that extends into the odometer area. In this picture, you can see it crossing the 7 in the 59557.2 odometer reading. (BTW that is 359,557.2 actual miles!)
I would have considered this "counter-balance" as logical and normal if it was on my '69 F250 or the '70 F350 at work, but it is not. Since you have to be moving about 15-20 MPH before it appears, it is difficult to tell standing still if any other '67-'72's have it also. I often thought it was molding flash that was not trimmed-off at the factory. (Sorta like the way glue-together models come packaged.)
And yes, the "counter-balance" disappears to the left of the first odometer digit when you reach 100 MPH.
Old Oct 23, 2002 | 09:31 PM
jds1971's Avatar
jds1971
I have a '71 and it does the same thing. It's normal.
Old Oct 24, 2002 | 07:07 AM
revrick's Avatar
revrick
Post Does Your Speedometer Do This?
Soooo you were driving and taking pictures at the same time??
Old Oct 24, 2002 | 10:09 AM
Ohio Bill's Avatar
Ohio Bill
Kris,
I am glad you posted this picture and query. My 68 F100 did not have a counter balance, but my "new" 72 F100 does. Took me about a week
of double-takes ("Is there a bug stuck in front of the odometer?
Hey, where'd the bug go? Am I going crazy?") to figure out what it
was. I'm glad to see that I'm not the only one...
Ohio Bill
Old Oct 24, 2002 | 11:29 AM
hawkrod's Avatar
hawkrod
there may be no bug but yes you are going crazy! you drive an old ford don't you? LOL hawkrod
Old Oct 24, 2002 | 08:24 PM
Like M. Fords
Thanks for the replys, guys.
The speedometer on this truck is a little more steady at speeds less than 20 MPH compared to the other trucks I drive that don't have the counter-balance; but I personally would prefer a bouncing needle at 10 MPH over an odometer that is partially blocked when driving. Either way, no big deal; it was just something that has been nagging on me for a while.
None of the roads around here are smooth enough to dake a picture while driving, so I jacked a rear tire up and put her in gear.
Old Oct 26, 2002 | 10:02 PM
jds1971's Avatar
jds1971
[updated:LAST EDITED ON 26-Oct-02 AT 11:03 PM (EST)]"...I personally would prefer a bouncing needle at 10 MPH over an odometer that is partially blocked when driving."
You're scaring me, dude.
What in the wide world of sports are you doing staring at your speedometer/odometer when running your missile down the road? You probably won't give a damn about it any more when you run your truck into the grill of a Peterbilt. Or how about through a bunch of kids crossing the street.
I hope I don't find you in my neighborhood- I'll take you out before you take someone else out.
We gotta be a little more careful out there, people. We're not the only ones out there when we climb into our rides.
Joe
Old Oct 28, 2002 | 09:58 PM
Like M. Fords
Well, I guess as long as I am in my own lane then the Peterbilt will be okay, and as long as I am not in your neighborhood, then I will be okay.
I have hit three deer (two in one whack), two porcupine, an elk (he hit me actually), a grouse, an owl, a few bats, some frogs & snakes, and about a dozen cats. Not once was it from staring at my speedometer/odometer... I take that back, I may have hit a butterfly once while checking my speed.
Old Oct 28, 2002 | 10:08 PM
sullyda1's Avatar
sullyda1
>her in gear.
Old Oct 28, 2002 | 10:16 PM
sullyda1's Avatar
sullyda1
Hmmm. Your message got me thinking. Recently my speedometer indicator on my 67 F100 started bouncing between 50-65 mph when accelerating. Once I would let off the gas and maintain cruising at those speeds the bouncing would stop. Thinking a cable problem, I installed a new cable. Now the speedometer needle bounces like crazy between 5 - 25 mph before settling. I was going to live with it. But it sounds like some of you are very familiar with speedometers. Could it be a counterweight problem?
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
