Code 327
Old Apr 5, 2006 | 08:54 PM
chinookdriver's Avatar
chinookdriver
Code 327
Got a code 327 (EVP below min voltage) on my 93 F150. Also have a shudder in the transmission if I have a load or trailer and have to go up an type of hill. Otherwise shifts fine. Called a mech he said problems in the EGR system can cause a shudder in the transmission. Something about the engine not being able to put out the proper power. Anybody ever heard of this? Also checked the EVP and it had the volts from the PCM and the proper resitance. Could the EGR valve be sticking causing that code? Looks easy enough to change but "Murphy" likes to raise up sometimes and make things more diffcult then they look. Thanks for any help.
ShadowWolf
Jun 13, 2012 05:10 PM
pmibach
1978 - 1996 Big Bronco
Aug 18, 2009 02:21 AM
tapenick
Aug 15, 2002 11:56 PM
tapenick
Aug 15, 2002 09:09 PM
