Sponsored by: Real Truck
CPS removal/replacement question
Old Apr 5, 2006 | 09:50 AM
BJB6521's Avatar
BJB6521
Is it just a removal/replacement of the sensor or is their timing issues and procedures that need to be adhered to?
Old Apr 5, 2006 | 03:17 PM
biz4two's Avatar
biz4two
Thumbs up
Yes, it is just remove the old failed CPS and install the new CPS. Of course, it is always good practice to disconnect the neg battery cable when working with sensors.
*Install Instructions:
To fix it, you’re going to need a 10mm wrench (or socket with a short 3" extension. A flathead screwdriver and a replacement CPS.
*Locate the CPS:
It is on the passenger side of the engine block. Accessible from under the truck, and located about the 10 o'clock position behind the crankshaft front pulley. Reach up and unplug the wiring harness, remove the 10mm bolt, and GENTLY pry the bad CPS out with the flat screwdriver.
Installation is just the reverse...***but a good idea to add dielectric grease to the plug.
Hope this helps...
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Apr 5, 2006 | 04:01 PM
dagren99's Avatar
dagren99
Smile CPS Install
Don't forget to put a little engine oil or O-ring Lube on the CPS o-ring. Helps w/ installation & prevents tearing of the o-ring.
DG
Beaters
Jan 12, 2016 09:55 AM
fabieber
Oct 21, 2015 09:31 PM
JohnDigger
Jul 18, 2015 09:27 PM
norm9759
Jun 14, 2015 03:28 PM
