2 or 4 bbl carb setup?
Old Apr 5, 2006 | 06:03 AM
cujo8's Avatar
cujo8
I am building a nearly stock 1977 302 engine using a stock crank, 0.030" oversized flat top pistons, stock cam, 1990 E7TE heads. I am debating whether to stick with the stock 2-bbl intake and carb or go after a after market 4bbl intake and 650 carb. I am not trying to build a race engine, but I would like good performance and fuel economy. What do you folks think? Thanks.
Jim
Old Apr 5, 2006 | 06:45 AM
smallblock351w's Avatar
smallblock351w
id put an edelbrock performer intake on it and either an edelbrock carb or holley. 600 cfm should be about right
Old Apr 10, 2006 | 05:52 AM
cujo8's Avatar
cujo8
Well since my exhaust system needs to be replaced and the stock exhaust pipes are insanely exspensive I have decided to buy an exhaust system from Summit for less than the cost of the stock x-over pipe. Since my current two bbl carb choke set up is actuated by exhaust gases from a port on the stock exhaust manifold, I have decided to go for after market intake and 4bbl w/ electronic choke. I purchased a Weiand model 8011 Aluminum intake and a Holley 600cfm carb w/ Vacuum secondaries and an electronic choke setup that I believe will work quite well with my application. It is funny how one thing seems to lead to another.
Jim
Old Apr 10, 2006 | 01:45 PM
kopfenjager's Avatar
kopfenjager
I think with a fairly stock set up your 2V manifold and carb will give you the same mileage as a 4V would. You will lose a little power with the 2V, but you have it now and you can always upgrade later.
I have a article on building 302s and it says stock manifold and rejeted carb for a cam upto 204/214 .050 duration. Also says stock manifolds with pipes no larger than 2" max for a dual exhaust. This info was gleaned from many different 302 builds and dyno tests. The headers and manifold are good upgrades but only if you have a cam to take advantage of there ability to flow. If you staying nearly stock, stay nearly stock.
My 2 cents.
Old Apr 12, 2006 | 08:53 PM
cujo8's Avatar
cujo8
Well I have decided against staying completely stock. I purchased a Weiand model 8011 Aluminum intake, Holley 600cfm carb w/ Vacuum secondaries, 1990 E7TE cylinder heads so far. I plan on purchasing headers and installing dual exhaust, so I am also planning to purchase a better cam as well to complete the package. I will also be boring out my cylinders out 0.030" and installing 0.030" oversized flat top pistons. Anyone know the volume of the E7TE heads so I can calculate me compression ratio?
Thanks.
Jim
Old Apr 13, 2006 | 06:44 PM
jade79's Avatar
jade79
60 to 62cc depending on factory tolerances.
dusty2052000
Mar 20, 2006 09:23 PM
icuhatn99
Feb 5, 2006 10:35 PM
flyflinger
Nov 16, 2005 11:52 PM
Chris 73
16
Jun 7, 2005 01:08 AM
serving_time
89
May 25, 2004 07:25 PM
