Engine & Transmission Swap
Old Apr 4, 2006 | 10:47 PM
fordflaresides's Avatar
fordflaresides
Here it goes, I finished restoring my 1973 F100. So now I'm looking to do a custom job on my 1978 F100 Flareside. The truck currently has a 300 inline 6, 3 speed, and 9" rear. What will I need to drop in a 351W H.O. and C6 Auto.
Heres the list I've come up with.
Motor Mounts (Will I need new perches too?)
Transmission Mount, Crossmember, and Driveshaft Yoke
Kick down lever & B&M Shifter
Radiator & Cooling Lines For Auto
Alternator Bracket (Alternator will be my only accessory unless you count w.p.)
Am I mssing anything.
Old Apr 5, 2006 | 08:02 AM
1975Ford's Avatar
1975Ford
Heavier set of front coil springs.
Engine towers (perches) for a 302.
Exhaust pipes.
Will need engine oil, oil pump sump facing toward rear of engine.
Shorten driveline and have a machine shop weld and balance with slip yoke for c-6.
The existing crossmember should work.
https://www.ford-trucks.com/forums/s...5&postcount=31
https://www.ford-trucks.com/forums/s...ht=300+to+351w
- - - - - buck - - - - -
luvmytruck460
Jan 14, 2006 05:34 PM
Kazco
Dec 10, 2004 12:24 PM
bluestang65
Jul 11, 2004 09:52 PM
alex crease
Engine Swaps
Apr 17, 2004 11:04 AM
swirk
Mar 1, 2002 08:34 AM
