date codes on tires
Old 04-04-2006, 09:12 PM
paul812's Avatar
paul812
paul812 is offline
date codes on tires
does anyone know if manufactures put date codes on tires, (i would think so) and is there a std for de-coding it? Would it be the no. & letters after DOT? thanks...paul
Old 04-05-2006, 05:22 AM
SRD4X4's Avatar
SRD4X4
SRD4X4 is offline
The last 4 #'s. The first 2 are the week and the last 2 are the year. i.e (0298) means that tire was produced the second week of 1998.Though some manufacturers will use a 6 digit code,(021998).
Old 04-05-2006, 10:54 PM
paul812's Avatar
paul812
paul812 is offline
thanks...but i see alphanumeric letters and no's right after the DOT. I'll look further around the tire. thanks...paul
Old 04-06-2006, 07:12 AM
SRD4X4's Avatar
SRD4X4
SRD4X4 is offline
Check on the other side of the tire,there are DOT #s on both sides.The date code is at the end of the serial no.If it's a "white" wall/letter tire it would be on the "blackwall" side.The DOT/serial #s are more of a "raised" letter/no.,where as the date will look more like it's stamped into the tire.
Paul Therriault
37
07-01-2023 10:28 AM
Paul Moody
02-27-2008 09:49 PM
PAUL_2
06-08-2000 07:42 AM
PAUL_2
05-16-2000 10:07 AM
Quick Reply: date codes on tires
