Sponsored by: Kumho
steering help for a 77 4x4
Old Apr 4, 2006 | 04:47 PM
joshsombo's Avatar
joshsombo
I need a little help from anyone who has had similar problems. My steering fluid has been leaking for some time. Now it seems that it is spraying out like a sprinkler. I could hear that there wasn’t any fluid left, and when I lifted the hood it was all over inside. It has really made a mess. It seems the steering pump is ok since it is not leaking. Could it be just a donut between the gear box and steering shaft that is old and needs replacing? Or do I need a whole new gear box. This may not be enough info. I have been adding fluid often for a while now. But it seems that has all come to an end and something needs to be replaced before i drive it again. Any help would be great. Thanks.
Old Apr 4, 2006 | 10:00 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
have you check the return and pressure hoses???
your cap isnt popping open a little is it?
Old Apr 5, 2006 | 10:38 AM
73Custom's Avatar
73Custom
I would first suspect a blown hose. Clean the area, fill with fluid. Then start it and check for leaks, may need someone to turn the wheel while you look for leaking fluid.
Marty
bismic
Mar 7, 2026 11:32 AM
bismic
Mar 9, 2022 09:20 AM
majestek12
Sep 16, 2015 02:06 PM
redman84
17
May 29, 2013 12:38 PM
AllaboutMPG
Feb 27, 2012 02:51 PM
