Windshield Removal
Old Apr 4, 2006 | 08:43 AM
btacarlton's Avatar
btacarlton
Windshield Removal
Can anyone tell me if, when installed, the windshields on our trucks used a sealer as well as the gasket? I am going to the parts yard today to get a windshield for my truck and they won't remove it for me. So I need to figure out what to bring with me to get it out. Thanks.
Bill
Old Apr 4, 2006 | 08:59 AM
77460f150's Avatar
77460f150
These trucks do not use any other kind of sealer except for the rubber gasket/seal. I have however seen some people use other kinds of sealer on them if they leaked after installation. I would assume you will be installing a new gasket/seal when you install to your truck so, to remove the glass from the part's truck just use a razor knife to slice the old gasket/seal and push the glass out of the window frame from the inside. -Ed
Old Apr 4, 2006 | 09:03 AM
btacarlton's Avatar
btacarlton
Thanks for your help.
Old Apr 4, 2006 | 09:04 AM
fellro86's Avatar
fellro86
The gasket is all that keep the windsheild in, but it is always possible someone may have used sealer along the way. A good sharp knif would take care of the gasket though. There is a proper procedure for getting it out, if you wanted to salvage the gasket, although, it is recommended to put a new seal in when replacing the windsheild. According to my Haynes manual, you remove it much like the rear window, and reinstall about the same way. I still would sacrifice the gasket for removal to reduce the risk of cracking it while removing. If you can get your hands on some piano wire, it wouldn't be bad to have along, (many body shop supply places will have it)
Old Apr 4, 2006 | 09:07 AM
derherr65's Avatar
derherr65
Just do not nick the edge of the glass! It creates a stress riser effectively. That one little nick will half the strength of the glass. I found out the hard way.
Old Apr 4, 2006 | 09:08 AM
little tow's Avatar
little tow
If is just the old windshield rubber - the oldest method is to sit in the seat with both feet against the windshield and push with both feet. Try to sit in the center of the seat with both feet an equal distance from center and pust steady and gently. Has worked in the past.
Old Apr 4, 2006 | 10:33 AM
Mil1ion's Avatar
Mil1ion
If it is a 78 or 79 the chrome strip around the windshield is part of the integrity of the galss.
This needs to be removed first, otherwise you will break the glass when trying to remove it.
If the windshield rubber doesn't have this windshield locking strip you do as what was mentioned above.
Piano wire with a wooden handles works well to cut the rubber too.
Old Apr 5, 2006 | 10:55 AM
79brncnwht's Avatar
79brncnwht
Is there any thing else to becareful of when removing a windshield that is in good shape?
Old Apr 5, 2006 | 11:00 AM
fellro86's Avatar
fellro86
don't let it twist, or it will crack, that's why I would rather sacrifice the gasket over chancing damaging the glass by trying to just push it out...
Old Apr 5, 2006 | 12:42 PM
btacarlton's Avatar
btacarlton
I actually removed it last night. Just put a new blade in the razor knife and removed the chrome corner pieces and cut all the way around. It came out pretty easily.
Old Apr 5, 2006 | 03:12 PM
Brewski's Avatar
Brewski
I'm guessing you didn't save the gasket then? I wonder if the removal can be done saving the glass and gasket. I just installed a new windshield 6 months ago! I've got the wide chrome trim.
Old Apr 5, 2006 | 07:30 PM
fellro86's Avatar
fellro86
New gaskets are more flexible, so they will be easier to get out, while the older ones aren't as easy to salvage..
Old Apr 5, 2006 | 09:27 PM
Mil1ion's Avatar
Mil1ion
If they are done in a heated area and someone flips over the rubber hold down contour,you can get the glass out without breaking it.
It takes 3 people min though.
Old Apr 6, 2006 | 12:19 AM
lscolonel's Avatar
lscolonel
Brewski, where did you find the seal? I can't seem to find a gasket for the chrome trim the guy at my local glass shop didn't even know where to look.
Old Apr 6, 2006 | 06:31 AM
77460f150's Avatar
77460f150
Check out the site sponsors, most all of them have the seal available. I got mine at LMC but, I have seen them at Jeffs bronco Graveyard and some other site sponsors. -Ed
