I always found that I would encounter excessive sway long before any danger of the trailer "lifting" the the rear of the truck. just trying to share my experiences.
very true about conventional trailers, not so much with a gooseneck
26455. In respect to any motor vehicle designed, used or maintained primarily for the transportation of property which is not equipped with a plate or marker showing the manufacturer's gross vehicle weight rating, for purposes of stopping distance requirements, the weight of a vehicle shall be determined as follows:
(a) Any motor vehicle having less than six wheels is the equivalent of a vehicle having a manufacturer's gross vehicle weight rating of less than 10,000 pounds.
(b) Any motor vehicle having six wheels or more is the equivalent of a vehicle having a manufacturer's gross vehicle weight rating of 10,000 pounds or more.
Declared Gross Vehicle Weight Limit Violations: Penalties
42030.1. (a) Every person convicted of a violation of any declared gross vehicle weight limitation provision of this code, shall be punished by a fine that equals the amounts specified in the following table:
[Fines imposed for a conviction of a violation of operating a vehicle in excess of it's declared gross vehicle weight.]* Pounds in Excess of the Declared Gross Vehicle Weight Fine
1,001-1,500 $ 250
1,501-2,000 300
2,001-2,500 350
2,501-3,000 400
3,001-3,500 450
3,501-4,000 500
4,001-4,500 550
4,501-5,000 600
5,001-6,000 700
6,001-7,000 800
7,001-8,000 900
8,001-10,000 1,000
10,001 and over 2,000
(b) No part of the penalties prescribed by this section shall be suspended for a conviction of any of the following:
(1) Section 40001 for requiring operation of a vehicle upon a highway in violation of any provision referred to in this section.
(2) Any provision referred to in this section when a second or subsequent conviction of a violation thereof occurs within three years immediately preceding the violation charged.
*The bracketed information has been added editorially to meet accessibility requirements and is not part of statute.
Added Sec. 58, Ch. 861, Stats. 2000. Effective September 29, 2000. Operative December 31, 2001.
Definition:
289. "Declared gross vehicle weight" means weight that equals the total unladen weight of the vehicle plus the heaviest load that will be transported on the vehicle.
Added Sec. 13, Ch. 861, Stats. 2000. Effective September 29, 2000. Operative December 31, 2001.
Lots of good info and I can second RV_Techs concern with some of the RV haulers out there, especially the ones who haul fifth wheelers. As a rule of thumb I try to haul at no more than 80% capacity of the tow vehicles capacity. All of my travel trailers have had 10% to 15% tongue weight but my fifth wheeler is close to 20%. Most trucks can haul a heavier trailer than fiver because of this.
regards
rikard
i have a 79 f100 with a 352 and a granny 4 speed tranny not sure about my rearend tho but im looking at pulling some tractors and hay and maybe a horse trailer. so i want to know how much i should be able to pull
I have a 2005 F250 6.0 King Ranch Diesel, 4x4, with tow haul. I could not pull that much weight. In fact, I am trying to find out how much I can pull. The manual that came with the truck says 12,500 with crew cab, SWD. The tow chart on this website says I can pull 15,400, but when I put the king pin weight in the calculations it tells me I am over weight for tounge weight. I am looking at a 37' Montanna fifth wheel that weighs 12,600 with a tongue weight of around 2000 lbs. Can I pull it and be within my weight limits? Rear end is a 3.73 with a 6800 pound weight. My salesman says yes of course, that everyone is pulling them with these trucks.
I guess I'm unclear as to how you are coming up with your trailer weight. Simply using the dry weight on the label is not a good indicator of your actual tow weight it does not include accessories such as the awning and you should anticipate adding about 900 - 1000 pounds of belongings. To actually know if your truck can handle the weight, you have to know what the actual weight is. I routinely encourage folks to weight a trailer before purchase.
It is not uncommon for fifth wheels to run more than 15% on their pin, although I would anticipate you would have at least that on your hitch.
I think everyone is saying the same thing in different ways.
First find out the gross vehicle weight rating (GVW) for your truck. Look it up, check the sticker on the truck, etc. That is the maximum amount of weight your truck is capable of stopping and carrying on its axles, wheels, etc. according to the manufacturer.
Its easiest if you fill your truck with fuel, then take it to a truck stop and run it up on their scale. Doing that you know your truck's weight with a full tank and you driving. Next estimate the weight of your passengers, add another 150 pounds for your hitch and maybe a couple of hundred more for what you will throw into the bed when you are towing. That should get you close to your truck's weight ready to tow.
Take that weight and subtract it from the gross vehicle weight rating (GVWR) of your truck and you will know how much weight you can put on the hitch i.e. your pin weight.
Next multiple the gross weight of your trailer by 15% to estimate the weight your trailer will put on your hitch. (I tend to add a 1,000 pounds to the trailer sticker before figuring because I tend not to trust the sticker weights on the trailer, unless I actually weigh it).
Since you know what your truck can handle and about what your trailer is going to add to the truck's weight, you should know if you are over or under the weight rating for your truck.
