Correct oil for NP435 / NP205 Combo
  #31
Old 09-08-2006, 08:58 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
Up in NC you must get below 30 degrees F in the winter, a good test on your synthetic tranny oil, post news at 11.
.....=o&o>.....
  #32
Old 09-10-2006, 04:01 PM
Brian460's Avatar
Brian460
Brian460 is offline
I never really paid attention to the ease of shifting, so I guess that means it was usaully fine.
  #33
Old 09-29-2006, 10:24 AM
Unimog005's Avatar
Unimog005
Unimog005 is offline
"For the 203/205 use what manufacture recommends."
Hmmmm, this seems to vary depending on which truck maker or which particular "reference" you use......and it seems I've gotten a plethora of different options for this one......I still need an answer as to what to use in the t-fer case....is it 50wt? 30wt? one of those with this "honda motocycle formula" added?
  #34
Old 09-29-2006, 11:09 AM
1975Ford's Avatar
1975Ford
1975Ford is offline
A synthetic 75w90 gear oil is what I use on the transfer case.
or straight 30 w oil for use in the colder climates or a 50w for hotter climates.
Oil made today are made to a higher quality oils standartd.
  #35
Old 09-30-2006, 01:36 PM
Unimog005's Avatar
Unimog005
Alright....I think I'll go with synthetic 75w90 for tranny and t-fer and 80w90 in the diffs....simple enough.....
  #36
Old 07-30-2009, 03:19 PM
shanes66charger's Avatar
shanes66charger
shanes66charger is offline
I would use full syn 80-90 marine gear lube.
  #37
Old 06-04-2015, 11:45 PM
SKYHIGH77's Avatar
SKYHIGH77
SKYHIGH77 is offline
so 80w90 in both the 435 and the 205 ?
Kyle Wood
10-19-2016 11:28 PM
1978crewcab
09-30-2016 09:18 PM
KsHighboy
01-21-2016 01:46 PM
ktownford
02-19-2004 08:06 PM
rustyolred27
03-24-2003 11:45 AM
Quick Reply: Correct oil for NP435 / NP205 Combo
