1978 - 1996 Big Bronco
Roll Bar for 1990 Bronc
Old Apr 4, 2006 | 07:48 AM
1990fordbronc's Avatar
1990fordbronc
hi quick question for everyone....where can i buy a roll bar for my full size 1990 ford bronco EB? i want one where i can take the top off and it will look cool and keep the roll bar on when the top is put back on...thanks
Old Apr 4, 2006 | 08:15 AM
Kemicalburns's Avatar
Kemicalburns
check out this place www.swracecars.com they make a pre bent/cut roll cage for our broncos. you will need someone to weld it up for you and figure out a way to tie it into the frame. if you dont do this last part the roll cage would be worthless in a rollover situation
Old Apr 4, 2006 | 02:46 PM
poffutt's Avatar
poffutt
Kem, are you sure that site is typed correct, I get an error "can not find site"
Old Apr 4, 2006 | 02:55 PM
Kemicalburns
try this one then http://swracecars.com/shippinginfo.asp
copy and paste into your browser
Old Apr 4, 2006 | 06:26 PM
JetBlackBronco's Avatar
JetBlackBronco
i just got a roll bar from a 78, on ebay. size-wise fits great, but i need to make feet for it, cuz the floor is a differant shape. then im gonna have 2 rear bars made up, and welded up. so the whole back will be caged, as for the front, if i cage it, i wont be able to get in very easy(being that i am 6'2", and have long legs) i would hit my knees on the bar constantly
Old Apr 5, 2006 | 08:41 AM
Kemicalburns
a cage is pointless unless it has some way to tie into the frame. if you were to roll the bars even with the plates in place would push thru the tub.
Old Apr 5, 2006 | 07:50 PM
JetBlackBronco
well i intend on a wide footplate for the bar, and prolly make a cross bar under the body from angle or box section. and tie it to the frame somehow
Old Apr 5, 2006 | 10:21 PM
justshootme84's Avatar
justshootme84
KB has the correct website (but it may be blocked from here):
S&W Racecars
I have their 10-point cage kit in my 84 Bronco. Check my gallery at:
superford.org
for lots of pics on the install. JSM84
Old Apr 7, 2006 | 02:40 PM
drduktayp's Avatar
drduktayp
I've been looking at roll bars as well including looking at all of Justshootme84's photos. I saw a roll cage through bolted from the cage down through the body to a plate that had a urethane block between the tub and frame plate which was then bolted to the frame. You can see what I mean at http://www.sierrajeep.com/fullcage.htm It looks pretty sweet. I hope to do this myself and am seeing about materials now. If the shipping isn't too high I will go with the SW product, otherwise I need to find a tube bender as I only have a pipe bender.
DrDuktayp
Old Apr 7, 2006 | 10:23 PM
justshootme84
I believe the S&W Racecars kit when you order it can now be had with those frame extensions, or you can easily make them yourself. I found several styles of mounts to tie the cage to the frame by searching at Pirate4X4.com, so that site is a must for any cage design questions. I decided on the bushing mount at the frame to give flex, since that design pictured at sierrajeep can still have stress on the weld at the frame. While a direct weld to the frame of the tubing is the strongest, I know of a few instances where the cage flexxed enough to break the frame welds or bend the mounts. Having a urethane bushing in that instance will help, but then you rely on the strength of the tubing that the bushing is in as well as the bolt(s) holding it in. I used the same 1-5/8"x0.135" wall tubing for the bushing mounts and 1/2" grade 8 bolts on the plates, with a 5/8" Gr8 bolt inside the bushing.
FractureCritical
Apr 17, 2017 02:03 PM
JoeVR
Feb 26, 2017 05:12 PM
GTT78
May 11, 2016 09:19 PM
dylanellis
17
Sep 3, 2011 11:47 PM
